110 vs 120
Home Forums General Bike Talk 110 vs 120
This topic contains 13 replies, has 0 voices, and was last updated by  Adrian Gale 10 years, 8 months ago.
  • #104510
    Evan
    Im thinking of trying a 120 rear, only ever used 110, surely it could only increase traction, is there any reason not to ?
    #262194
    Hi BelligenEv,
    my 300 exc had the 120 standard and I found the 120 hard to get , but torpedo 7 had them.
    I liked them. But I’ve gone on to the Moto Z hybird. It’s got about 850+ k’s, I run it at 6psi not going back.
    Cheers Gordo
    #262198
    My Beta 450 came with a 140 and i changed to a 110 , the faster turning was the main improvement in tight singles , not sure about traction overall ( I guess your talking hard hills Ev ?) I’d be keen to know your findings if you go the 120 , a tyre that can handle low pressures without trashing the side wall would have to be important too !!
    #262199
    Evan
    a mates been using them for a while I rode his wr and couldn’t notice any difference in the handling and hes never had a flat, its interesting the Beta came with a 140, they must do that for a reason, what did the dealer say? I wonder what romaniacs use
    #262201
    The larger 140 on the rear seems to be the extreme riders choice, maybe with a mousse tube , I think that’s the equivalent to 8-10lb could be wrong ??
    #262202
    Those 140 tyres are the same size as most 120s. Different brands have different sizes. Michelin 140 = Pirelli 120 etc….
    Whatever you do Ev stick with a 100. 110/100 or 120/100.
    120/90 will have a lower profile side wall than a 110/100
    #262195
    Just give it a try Ev, like LC said be aware of different sizes with same numbers on different brands (does that even make sense :huh: ) And like Jacko said, I notice our WRs don’t turn as well with 120’s as they do 110’s, the bike pushes the front. Cant say I really notice a traction difference being a 250. I ran Dunlop 120’s on the XR650R and width wise they were just a bees dick narrower than a 140 S12 Michelin.
    Try it in short ;)
    I went to a Pirelli Scorpion mx extraX 120/100/18 on the rear of my 300 and I think it is great. Great grip in the wet stuff and on the singles. Prior to this I had a Dunlop 100/100/18. not a bad tyre but I was frequently getting pinch flats with that tyre and have had none since going to 120 and still run the same pressure etc. Probably just a coincidence and I will now get 3 flats this weekend. The 120 beside a 100 is significantly taller and maybe a little heavier. But I will be sticking with the 120 from now on. Try the 120.
    #262211
    Evan
    Food for thought, gotta say im tempted to go even bigger after hearing nicks Beta came with a 140, it sucks though that the sizing isn’t accurate, a 140 in a rut dug by 110s would have to get more traction, hey nick what brand was the 140?d do you still have it?
    #262215
    Mine was a Michelin Cross comp 140/80 x18 from memory , I think the 80 is the percentage of depth in relation to width ( could be wrong again !!) ?? Either way it was a fat beefy tyre and did the job , I only replaced it because I was used to a narrower tyre !! These days I don’t really care that much if it has grip then it’s my job to scrape together the talent to make it work :D
    After all Spud uses a Chinese swallow , rock hard, no size , almost bald rubber ring and smokes us all :D
    #262216
    I suppose I should add that learning how to ride will help you get up hills Ev!!! Haha
    And get a Pirelli MX or XC mid soft 120/100
    #262222
    Evan
    do you know anyone that could teach me?
    #262197
    When I visited the Sherco factory a couple of years ago, all the 300 4 strokes where delivered standard with 140’s. Maybe this was just for Europe?? Cheers budge
    #262223
    Adrian Gale
    120/100. Just better.
