1980 TS 185
Home Forums Tech Help Tech Help 1980 TS 185
This topic contains 11 replies, has 0 voices, and was last updated by  Greg 15 years, 3 months ago.
  • #99224
    John
    I’ve just got myself a badboy Suzuki 1980 TS 185 but as this is me first two smoker i’ve got a couple of questions.
    1. It has a self mixing oil tank (for the fuel). If i just mixed my own fuel and oil do i need to do anything to the oil tank.
    2. What oil/fuel ratio do i run.
    Any help greatly appreciated.
    #191729
    I converted both our PW50s to premix. I just disconected the oil pump inlet and outlet lines and then hooked them up together so that there is a constant cycle of oil running around the pump.
    As for fuel mixture 32:1 should do. 125ml to 4 litres of fuel.
    #191732
    John
    Thanks Mick.
    So does that mean i leave oil in the tank ?
    #191733
    No, There is a small amount of oil in the pump that will go round and round if you join up the hoses. Just drain the oil tank or block off the outlet. On the PW’s I took the tank off completely.
    #191734
    John
    Thanks Mick. Good work ;)
    #191737
    The reason I joined up the hoses in the first place, was that I might want to run the oil tank again in the future and it just stops the pump from running dry.
    #191730
    Scott
    I’m not sure where the pump is located on the TS. But on most bikes you can just unbolt the pump. And install a block off plate, A peice of alloy or steel the same shape as the flange on the bottom of the pump.
    Remove the tank and plug or cap where the oil was being injected into the inlet.
    32.1 would be ok but probably very smokie and may fowl plugs easily I would run 50.1 with a good quality oil. If you want to be on the safe side 40.1
    #191749
    John
    Caltex Vortex 95 ok for fuel ?
    #191750
    Scott
    Yep Fine
    #191751
    A very knowledgeable 2t tech bloke recently told me that it is the oil that determines the mix ratio not the bike.
    So whatever the oil manufacturer recommends is the go.
    Little word of warning SOME self oilers have a bearing recess that will get no to very little oil from premix as the gallery is a bit funky in design, just check this out first, personally I’d use the self oil function once set up they’re pretty damn reliable on the old ER185.
    #191758
    Aaron Wilde
    Is weight the only reason you would want to premix. My MX 100 had a tank and it was very easy. Think the complete name for the ER was TS ER 185s Can’t work out why you wouldn’t just say that. :laugh: Classic bike. One tried to come between me and my bike once, bitch. But it ended up going between the back wheel and the exhaust and ripped it off! :laugh:
    #191759
    I am with Mr Blue why remove the oiler if its working? They are reliable as the day is long. The bike was designed with it, they work great, our pee wee had one and it worked great. I couldnt understand why anyone would remove it unless they were racing them hard core. If I was to remove it Jak I would remove the pump and fit a plate like Badbowie said. The KTM 50 we owned here had the auto system removed and it was plated, seemed like the best way nothing to leak, go wrong, have the pump run dry, etc
    Only my opinion
