This topic contains 55 replies, has 0 voices, and was last updated by Paul 15 years, 6 months ago.
September 4, 2010 at 7:29 pm #186962
Good stuff Menace. A good tutorial that will give other guys the confidence to have a go themselves.
September 4, 2010 at 11:26 pm #186963You’re using Motul 800 aren’t you Mr Menace?
On ring end gap, it depends on the type of rider you are, the air filtration, oil type, ring material quality all these things combine to give wear rates.
I am a bit surprised that the powervalve was that gunked up in 100 hours, the flapper on KTMs and sub-ports usually defy this for a few top-end changes, another hint for cleaning them is believe it or not CRC556 or WD-40, I reckon the hydro-carbons are the trick…
But all in all a job well done and done in good timeliness, now you can ride and ride and wear it out again…..
September 4, 2010 at 11:45 pm #186966it wasnt really gunked up, just a layer of crap like plaque that chipped off.
i dont think i really needed to clean it, it was a learning exersize more so.
but yes mate, its always motul 800.
September 5, 2010 at 12:19 am #186968Ring end gap is easy 4thou per inch of bore for soft riders
6 thou per inch of bore for some one that revs the motor hard or supercharge/turboto check piston to bore clearance i heat the piston in a pot of oil starting at room temp and go up in 10 deg incremt till piston wont go down the bore you want to do this fast as you want to keep the bore at room temp
what you are finding out is what sort of a temp increse you can get before it nips in the bore if you cant get to 80deg it will fail in short time
you can measure with dial bore gauge etc but wont take in to account the different expansion rates
September 5, 2010 at 12:38 am #186390Thanks for the read Menace,
Ill be checking a few more details when on my next rebuild,which judging by the way its not starting too well must be now.
gooday Bull, long time no chat.
that kinda makes sense. the 300 bore is 72mm, so nearly 3 inch and the specified ring gap is .3-.4mm (12-16 thou)
for soft riders like me anyway :laugh: :laugh:
your not just a pretty face Bill
buggered if im gonna go putting the piston in the deep fryer either…
i’ll just warm it up good mate :laugh: :laugh:
September 10, 2010 at 1:04 am #186588menace wrote:
Quote:if you look at the ‘prorider’ website, their kits are $239 but no group 2 in stock.
‘procycles’ (who are near suttos) do them for $263, and have group II pistons.Hmmm….. I looked some of this up myself just now.
Procycles website
Group I $289
Group II $263Prorider (rang them because their website is mental)
Group I & II $272When I spoke to Mr Prorider, I asked him what he recommended for say an 80hr 300, I or II.
He said I should measure it (fair enough). Then he said this: “If it’s too tight (Group II) then you risk “lipping” the piston”. “If it’s too loose (Group I) you risk not having enough compression” :blink: :blink:If I were him I would have probably said nothing or something more sensible like:
– Too tight = more risk of cold/hot seize or in other words too much ally on nikki.
– Too loose = risk of quicker wearing piston, piston rattle, broken skirts etc.Rang Ballards just for completeness, awaiting a call back on A/M kits.
Either way, I’ll be tearing down to measure first and going through Suttos in the end.
September 10, 2010 at 1:25 am #187226Ballards:
Wiseco $285
Vertex $277
Woosner $215
ProX $285
+ Gaskets $49
+ Small end bearing $15September 10, 2010 at 4:13 am #186391Dont forget you guys get an old bull Discount..
September 10, 2010 at 5:35 am #187242TISCO wrote:
Quote:Dont forget you guys get an old bull Discount..That makes the choice a no brainer. I’m sure we all will do what we can to support our sponsers! :cheer:
My notes above only show what a great deal we get through Suttos without a doubt.
The A/M kits are bad value in my opinion.
September 13, 2010 at 9:27 am #187248Great thread…thanks, I did mine at around 100 hours but diddnt go the OS piston just yet, heaps more grunt!
