38mm Mikuni jetting on XR600
Home Forums Rocks Motorcycles Honda Forum Rocks Motorcycles Honda Forum 38mm Mikuni jetting on XR600
This topic contains 61 replies, has 0 voices, and was last updated by  doug 16 years, 4 months ago.
Viewing 15 posts - 1 through 15 (of 62 total)
  • #97440
    doug
    so guys what jetting are you running on your XR600 with a Mikuni TM38-85 flatslide and what mods do you have. Need to get mine running better
    #158908
    When I had an XR630. I had the 38mm Mikuni and was running a 210 main and a 12.5 pilot from memory.(I am at sea level)
    If I ran a 200 main I found it would ping under load and at 220 you could near see pure fuel in the exhaust gases.
    Needle setting in the middle,I didn’t fool with that much but if I had, there probably would have been gains there too.
    Mick
    #158976
    doug
    thanks micknmeld what mods did you have done besides the 630 kit
    #158979
    Mine was a 1999 model and came brand new with the HRC 630 kit. I just fitted 14/48 gearing.Cr500 read guard and LED tail light. AS far as mods went,I didn’t do that many.The carby, a set of fat bars and risers. Pivot Pegz and that was about it. Because it was a XR I didn’t have to do much except change the oil and ride it.
    I also had a full staintune system on it for a while.
    #158980
    doug
    no air box mods or after market air cleaner
    #158981
    Not really just removed the snorkle thingy and put in a twin air filter
    #158987
    I love it when you talk technical :laugh: :laugh: :laugh:
    You forgot to mention the fantastic stainless steel oil filter and pespex headlight gaurd B)
    #158995
    Oh yeah and also the Old Bull Guard stickers that made it go like a scalded cat. :laugh:
    #159001
    doug
    Thanks micknmeld B) need to get me one of those Old Bull Guard stickers how much more Hp did it give you??? :laugh:
    #159014
    Bucket loads of power mate!! Well worth the $20 for the stickers. :laugh:
    One of the first rides with them on I managed to flip it and ended up with my foot in plaster (with a probable fracture).
    I would only recommend the Old Bull sticker upgrade if you think you can handle the extra HP. :dry:
    Another thing we found that will give you extra HP on a XR600 is to fit a set of spokey dokes to your front wheel. Moose’s XR rips with them on. ;)
    #159023
    doug
    mite have to raid the kids bikes to get some of them 😆
    #159031
    doug
    well i just got some jet i ordered they were 230 and 250 main so i put the 230 in to start well after some playing with idol and fuel screw is running tops reving clean and smooth no flat spot :) so it is of to take it for a test ride fingers crossed :unsure: it stays like that at WOT
    #159101
    Has it got a hesitation/bog of idle if you crack the throttle on?
    #159155
    doug
    it did have that is gone now
    well i just got back from a arvo ride not happy :angry: good down low but if i start giving it lots of 1/2 to 3/4 it will bog and i have to back off an clutch in and free rev it to stop it. So I need some help here to fix it or it will be up for sale and back to ome carby it was ok thought the Mikuni would be better not that i can see yet :angry:
