Home › Forums › Rocks Motorcycles Honda Forum › Rocks Motorcycles Honda Forum › 38mm Mikuni jetting on XR600
This topic contains 61 replies, has 0 voices, and was last updated by doug 16 years, 4 months ago.
November 7, 2009 at 4:29 am #159884
Does not look warn and moves up and down freely
November 7, 2009 at 4:34 am #159885its prably okay than
November 7, 2009 at 4:38 am #159886i have no idea it looks ok to me
November 7, 2009 at 7:15 am #159887madougxr wrote:
Quote:i have no idea it looks ok to meIs the tank fuel cap ok Ie no restrictions? you have to have a good airflow as well,try it with the cap removed,also see if you can fill a litre bottle with fuel from the hose. Caltex 98 doesnt have Ethanol,should be good,as rocket said it is definatley a fuel supply problem, is the filter in the tank Ok? just guessing now,did you try carby cleaner?
November 7, 2009 at 11:20 am #159890done all of that the tank filter was good and tap was ok also checked the cap and it is not blocked carby cleaned the lot so where do i go from here
November 8, 2009 at 12:11 am #159906madougxr wrote:
Quote:done all of that the tank filter was good and tap was ok also checked the cap and it is not blocked carby cleaned the lot so where do i go from hereI think we have covered everything, A carby is a pretty basic item, all I can suggest is to recheck the fuel supply from the carby inlet to the needle and seat,making sure all of the passages are clear,maybe use a small piece of flexible nylon down the passage. Other than that,you may have to bite the bullet and let a mechanic have a look at it.
Hope it goes well for you
BTW here is a exploded view it may help diagnose any problems
http://www.motorcyclecarbs.com/Mikuni_TM_Parts_W188C1652.cfm
November 8, 2009 at 12:28 am #159929well i am a car mechanic by trade so i have a pritty good idea on how they work but this one has got me bugged :unsure:
i have looked over that parts Diagram a million times but it is all there :dry:
the next thing i am going to look at is the floats they mey be the wrong ones for the carby :unsure:
thanks for your help Ollie
November 8, 2009 at 12:38 am #159930No worries mate
November 8, 2009 at 12:52 am #159932Mick any chance you could post some pix of your floats just wont see if my ones are the same cheers if you can
November 8, 2009 at 2:03 am #159933I dont reckon they would be the wrong floats.That is certainly drawing a long bow. :blink: Is the carby old and well worn? Have we explored float level? Even cable adjustment?
November 8, 2009 at 2:12 am #159936Can you source a carby for loan that you can fit, even a standard one that would tell you if its carby or fuel supply, and I dont have one anymore, Chicken may have I will see what I can find out for you
November 8, 2009 at 2:43 am #159937i have the standard one that i pulled off the bike to put the mikuni on the standard one was ok no probs with fuel supply with it on
how would cable adjustment help the cable is new anyway
the carby dose not look worn dont know how old it is as it was second hand
November 8, 2009 at 5:26 am #159941ok so i found out that the floats were put in wrong maybe by me :whistle: so that have fixed the fuel flow problem
now i have another problem and that is that there is fuel poring out the hose on the bottom of the carby only stops when you turn the fuel off is that to do with float level :unsure:
November 8, 2009 at 8:02 am #159959sounds like you have a lot of patiance think your on the right track but
November 8, 2009 at 9:14 am #159960madougxr wrote:
Quote:ok so i found out that the floats were put in wrong maybe by me :whistle: so that have fixed the fuel flow problemnow i have another problem and that is that there is fuel poring out the hose on the bottom of the carby only stops when you turn the fuel off is that to do with float level :unsure:
Yep that would be it
glad you sorted the fuel flow problemollie
