450 EXC Over Heating – Engine ICE
Home Forums KTM Bikes KTM Bikes 450 EXC Over Heating – Engine ICE
This topic contains 54 replies, has 0 voices, and was last updated by  Mick D 15 years, 5 months ago.
Viewing 15 posts - 16 through 30 (of 55 total)
  • #188047
    You need to check that boiling spec Hatto, 200 degs. 200 degrees celsius would be a fair claim to fame as water boils at 100 c there abouts and glycol under 15psi pressure boils around 114 – 117 c in our diesels on the dyno :blink:
    It cant be 200 fahrenheit either cause thats only 93 c
    I am curious as the the correct spec because its bloody good stuff, but I dont think its that good, although as always I could be wrong ;)
    Hatto wrote:
    Turkey slaps are bad for your health Mick, get off em
    $35 or cooked engine, I choose $35
    Hatto
    How much for a cooked Turkey :laugh: :laugh:
    #188049
    Craig Hatton
    http://motorcyclecoolant.com.au/
    Sorry, 190 degrees, read above ;)
    hatto
    #188050
    B) Liquid Intelligence 115 gives boil-over protection to 190ºC, so it’s thirty percent more thermal efficient than traditional water/glycol based coolants.
    #188052
    Craig Hatton
    That was quick ollie, we don’t get the chance to pounce on his lack of knowledge very often :laugh: :laugh: :laugh:
    Hatto
    #188053
    Now that I think about it, I remember Huskybloke telling me he had similar trouble on his Husky, (just 1 of the many though :D). He was telling me when mine boiled over one day and said he used the Ice and had no more troubles.
    #188020
    Peter
    Gents,
    I think you need to be careful with those fully synthetic ones … do you really want the water supposedly cooling down your engine pumping through it at 190deg C ?
    Think Trailboss mentioned something about the ability to absorb and then dissipate heat. Apparently water is the best at this, although we cant have pure water cos of impurities, corrosion and freezing issues.
    And that supposedly is the beauty of Engine ICE, contains pre-mixed distilled water and additive.
    http://www.engineice.com/faq.html
    #188054
    where is KTMBull, he has the answer…
    :P
    #188055
    Riggs wrote:
    Gents,
    ;) 190 c :ohmy: I still cant see it getting that high from experience really, but hey like I said what would I know :laugh: I would rather have an engine that didn’t get above 100 or even 95 to tell the truth and ran at 90 c would be nice
    TB :ohmy:
    #188056
    I’m with TB.
    Engineers design engine components to work within expected temperature ranges. Their known rates of expansion are taken into account when clearance tolerances are calculated.
    The above mentioned coolant replacement might stop boiling of the cooling system, but I reckon a aluminium piston would pick-up/ seize in a cast iron/ steel bore well before 190 degrees Celcius!
    Crash
    #188051
    Read the link, it has an explanation of how it works ;) 30% more efficient ie better than water/glycol at absorbing heat and then dissipating it to the radiator cores/fins.
    ian
    engine ice i thought was a good product the main thing i was having problems was in the tight tuff it would boil and then steam out the overflow and then lose your coolant .After replacing the motul coolant with that engine ice it never pinged or lost any coolant through steaming out the overflow and overall run cooler.
    #188065
    Fair dinkum, honest testimonial right there guys!! There’s a bloke that has used it and is singing its praises. ;) Might be worth exploring it’s benefits.
    Thanks Huskybloke
    #188066
    ian
    if i remember it was $29 for a 2 L container
    #188060
    Yeah Crash read the sales explanation from the sales department it couldnt be wrong :laugh: :P :laugh:
    I am not disputing the fact that the coolant is very very good but 190 degrees C and components running at that no way. Crash is a mechanic, I do this for a gig and teach failure analysis as well as other mechanical related courses and components just wont do it.
    I am not saying the coolant isn’t a good thing and solves overheating like in Huskyblokes example (thanks for a punters honest opinion :) ) Mal swears by it and Hatto but anything over 120 degrees and the pistons expansion will start causing problems.
