650’s V 450’s
Home Forums Ride Reports 650’s V 450’s
This topic contains 21 replies, has 0 voices, and was last updated by  Anonymous 17 years, 5 months ago.
Viewing 15 posts - 1 through 15 (of 22 total)
  • #95174
    The big Comparison day in the Watagans,
    CRF 450x 2007
    KTM 450exc 2008
    V
    Bikes tested Honda 07 CRF 450 and KTM 08 450 EXC
    The kato as an after market muffler fitted and don’t much else, thanks to Moto for the extanded ride time, was interesting to ride the CRF and then the EXC and get back on the CRF.
    I adjusted the ride height and sag on the CRF before I chucked it on the trailer. First thing I couldn’t help but notice is the ease of starting using the magic button, quick run down the dirt road and of onto the single trail, the first down hill, rocky, ruts and nice wash outs. Quickly the lighter weight of the bike showed itself, jumping ruts and steering the bike using the pegs is so much easier but I found the bike nowhere near as stable, I seemed to bounce from rock to tree root, it’s hard to explain. The throttle was very sensitive and when I tried to ride a gear higher the chain would rattle and it had no power to wheel stand over things.
    As the day went along I started to work out how to ride it faster but I was still having the odd moment here and there that I don’t have on the BRP.
    With the XR when you hit something it is very stable, I was finding I was less worn out physically on the 450 but more mentally taxed.
    I swapped with Moto, first thing I noticed about the Kato was how much better the brakes worked then on the CRF, they where stronger and had more feel. The front end on the CRF had more feel and steered better than the Kato and seemed much more progressive through the stroke of the suspension.
    The rear end of the Kato seemed better then the CRF, better in the smaller stuff yet soaked the big hits up without bottoming.
    Engine wise the Kato had a stronger bottom end and mid range yet the top end seemed no stronger than the CRF which was the same. After talking with Moto it was decided it could be the after market pipe that was helping the Kato’s bottom end, Moto also said the Kato was going in to be rejetted so he expected more from it in the future.
    I liked the Honda’s ride position more than the KTM‘s and the gearbox on the Honda also seemed a more direct shift and sweeter to use. Just on the KTM’s front end, Moto has been unable to remove the air bleed screws which would no doubt be helping cause the harsh action through the stroke.
    Back on the Honda I found I would tackle the nasty little tracks / hills / rock step ups without thinking about it much more than if I was on the 650, I was trying to work out was it because of the lower seat height (feet touch the ground much better ha ha) was it because it was lighter and I could pick it up easier if needed (I didn’t try the pick it up test all day thank God) or because if stalled I could push the button.
    The chain slap really gave me the s*#ts all day, I checked the chain when I got home and the adjustment was as per the manual.
    Thanks again to Grant aka Chopper for the CRF and Moto aka call me Dave for the Kato
    Also Champo offered me a ride on the TM300 which seems a sweet ride and I will take him up on it next ride, cheers mate
    #108855
    Hey did I read that right??? Somewhere in there, I am sure TB actually said something nice about a KTM!!!
    Well wonders will never cease!! Just when I thought I had him worked out!
    #108859
    I second TB’s opinion above mostly. I found the Honda suspension to be better overall and I rode it through the whoops on the way back quicker than I did my own bike. I did like the Honda gearbox, it was very schmick. I did find the brakes lacking some feel and power but I think that could be sorted with a better pad/disc combo.
    The bars were also a little short after coming off the KTM, again this is easily changed and I think would be required for a taller rider.
    I think stock for stock the KTM still has a slightly more response at the bottom end. This was further improved however, with my aftermarket pipe.
    Overall, I liked the ride of the Honda, and after I got used to the brakes I was moving along quite nicely on it. With all the extra gear you get with the new Honda’s like steering dampers etc, it would be a hard bike to look past for anyone after a 450.
    Cheers to chopper for letting me have a ride :)
    #108860
    Hey thats not fair! MIck I can be open minded lol
    I was faster on the Honda, thats all that counts!
    #108856
    Good stuff TB for the comparison. I be interested to see how ChiefGili’s late model WR450F annihilates, I mean, compares with the field of bikes you have tested. It is honest, unbiased (by advertising) opinions on bikes like this report, that really makes this forum a great asset to it’s members and host of lurkers.
    TB gets some karma for this, plus all the other stuff he does behind the scenes for this forum.
    #108857
    GP
    Trailboss I would like to hear your opinion about a 2-smoke bike… Its funny how light they are.
    #108977
    Yuri, I was offered a ride on Champo’s TM300 two dinger and I will take him up on it in a future ride, it was just that I was doing both the 450’s and wanted to just make sure I gave that the justice that I felt it needed to be fair
    Ha ha if I ride Champo’s for a demo, would Champo ride the 650?
    #108867
    Nigel,it would take too long to set up for TB to test Gili’s Yamaha, Gili is 70kgs wringing wet, TB is well errr ummm errr Portly?:unsure: :laugh:
    #108985
    Portly??? That is very PC of you Ollie…LMFAO
    adj., -li·er, -li·est.
    Comfortably stout; corpulent. See synonyms at fat.
    Archaic. Stately; majestic; imposing.
    [From PORT5.]
    portliness port’li·ness n.
    Here are some other words you could have used…
    Thesaurus: portly
    adjective
    Having too much flesh: corpulent, fat, fatty, fleshy, gross, obese, overblown, overweight, porcine, stout, weighty. See fat/thin.
    #108991
    [From PORT5.]
    Thesaurus: portly
    adjective
    #108997
    Thats not nice TBs only a little feller;) like myself:blush: just remember you need a big hammer to drive a big nailB)
    #109028
    Righto,
    Ollie, Mick and Moto in that order you guys are not playing very nice at all
    You are all being quite mean. :S
    Dont worry I could set Gilli’s bike up for a test run in about 10 mins, I have had test rides on a WR450 and WR250 (whole day on the 250) and I think the 250 was one of the best bikes I have ever ridden, 2nd only to a Honda (any Honda)
    [From PORT5.]
    Thesaurus: portly
    adjective
    Ha ha Mick, I LMFAO at you!!, nice use of the oxford and the sore arse:laugh: :laugh:
    Sorry TB Nooooootttt!!
    #109036
    xr torcher
    two words jenny Craig
    #109038
    For a guy that wants to stay in the back ground and not be named or known you talk alot X
    Jenny and the BRP seemed to track through your little tracks ok up there, I dont need Jenny thanks.
