660XTZ Rear Bearing Number
Home Forums Yamaha Bikes Yamaha Bikes 660XTZ Rear Bearing Number
This topic contains 1 reply, has 0 voices, and was last updated by  Greg 14 years, 2 months ago.
  • #100953
    Ian Carr
    Had the rear wheel off today for inspection to check out the cush rubbers and wheel bearings,noticed the bearing on the chain drive side outer a touch notchy ,Yamaha part No 93306-30437,does any Tenere owning OLD BULL,s know the bearing size number and the seal as well part No 93106-30029 it would be a great help,I could buy the parts from a bearing supplier and have them ready to fit for the Tenere Tragic,s ride, Thanks CHOOT. ;) ;)
    #214868
    Hey Choot, the hub bearings are 6203 front and rear. The cush drive bearing that probably needs replacing twice to every set of rear hub bearings are 6304
    You should really get new seals as well, the bearing shop can help you with them if they are half switched on
