690 enduro
Home Forums KTM Bikes KTM Bikes 690 enduro
This topic contains 9 replies, has 0 voices, and was last updated by  Joe 15 years, 1 month ago.
  • #99358
    Joe
    I was playing in the dunes today when the big girl started to cough as though it was running out of fuel.So I high tailed it to the servo, plenty of fuel.
    It wont idle or keep a steady rev. IT will hold 4000 rpm for a couple of seconds then die .If you back the throttle off & on a little it will surge before dieing again. I have checked spark plugs, fuel pump & air filter no luck. Has anyone had this before?
    I am a bit lost with EFI as I only had her for a week.
    :angry :angry: :( :
    #193606
    Joe
    :angry :
    #193607
    I sit getting enough air into the tank? maybe the breather is blocked.
    #193609
    Joe
    Fuel pump working fine.I think it may be a sensor someware.
    #193610
    There is a screen I think somewhere that blocks with some of the fuel injeced KTM’s
    Ring Sutto’s tomorrow after 10am, 47379566
    Check your battery connections or for loose/broken wires. I have seen an EFI bike run like a dog with loose/broken terminals.
    Mine has a dead flat battery ATM and runs very badly. New battery going in tomorrow.
    Hope this helps.
    #193611
    Joe
    Thanks guys
    Screen is clean on fuel pump.
    Battery turns over well
    Ill give Suttos a ring tomorow.
    #193612
    How did you go Tryhard? Any clues from Suttos?
    #193624
    Joe
    Impossible to diganose on the phone but they were going to fit me in over the xmass break ;) .But its a good 2 hours for me to get to Suttos so I ended up taking my old bike for a blast over the holidays instead.Just got back today,from the holidays not the ride :laugh:
    Have booked it in tomorrow for a plug in analysis at Newcastle KTM as they are only 1 hour away.Looking like a fuel pump $$$ :blink: .Will let you know what happens :(
    #193918
    Joe
    Fixed :laugh: :laugh:
    Simple connection fault on the oxy sensor. :blush:
    Alls well in the KTM garage for now :P
