99 cr250
This topic contains 8 replies, has 0 voices, and was last updated by  alan 16 years ago.
  • #98189
    stevie
    thinking about buying a 99 cr250. is 99 a good year or is it a p.o.s 3k53md3le5Tc5Pf5R9a39df2d588404e11302.jpg
    #173482
    If the price is right, she looks OK. Try and get the guy to throw that trick stand in on the deal and if the bike turns out to be a POS you can throw the stand through his window.
    In all seriousness, it is hard to tell from a small pic like that from the other side of the world.
    A few things to look at would be,
    does it start easy
    does it have any suspect rattles in the engine when it is running.
    does it have good throttle response
    Do the wheel bearings have any play in them.
    Same for the head stem bearings and swing arm linkages
    Any suspect oil leaks from the cases
    How badly dented is the expansion chamber.
    Are the chain and sprockets in good order
    It appears to have the original graphics on the radiator shrouds so that may indicate it hasn’t done that much work. I dont think that they are the original rims on it either.
    Just some things to ponder.
    #173483
    Scott
    I had one of this era back in the day. From what I can remenber heaps of balls but handled like a bucket. It used to headshake something bad like real bad. Spent a heap of money with Terry Hay for not much improvement. My brother had a YZ250 same year at the time suspension on that was sweet motor wasn’t as punchy but was just a s quick.
    #173486
    Used to ride a 96 with Crash it would shake its head tied on the trailer :ohmy: I dont think the trail or rake angle was changed between 96 and 2001 it was the time of supercross and the bike was designed to steer around a supercross track in 2nd gear railing berms. Punchy bottom end mid range motor again for supercross, loved the bike went forever.
    Jason Green
    She will be right mate its a HONDA
    #173504
    you forgot to mention to see if it blows lots of smoke Mick ;)
    but coming from an XR70 i’d be shopping for a KX/YZ/RM 65,
    seriously the 250 Will Chew you up and Spit you out, turn around pee on you and laugh up a lung at you.
    #173508
    Jesus that made me laugh XY :laugh: :laugh: :laugh: :laugh:
    One of the worst handling bikes ever made were the early alloy framed Cr’s, excellent motor (CRs always did have) but far too stiff lent over and transferred everything to the rider.
    Even McGrath stayed on the steel frames for a few seasons into alloy……
    #173563
    not wrong there mr blue jarred the crap out of you fast moters but i only rode a 98 model but .the 96cr250 was a sweet bike as TB said
