Aftermarket Fuel Tanks
Home Forums Yamaha Bikes Yamaha Bikes Aftermarket Fuel Tanks
This topic contains 6 replies, has 0 voices, and was last updated by  Chris 17 years, 2 months ago.
  • #95676
    On the lookout for aftermarket tank, just about every manufacturer does one for the WR just after some opinions on the different brands, ie clarke, ims, gytr, acerbis. Don’t want anything massive, one of them offers a 13L tank and some you have to change your rad shrouds to the yz ones to have a proper fit.
    #117987
    Have you considered a Nomad tank? One of the bum tanks that goes on the rear fender? That would get you about the 14 litre mark and is easily removed and replaced.
    #117995
    I used bum tanks for a few year when racing the Condo 750’s and Yellow Mountain events, they work ok, used to run the bike on those to it misfired and switched the front tank on and the rear of. I got caught up on a bum tank once and had a bad accident since then I haven’t used them and used different size tanks I am lucky as I have a 10.5L, 17L and a 28/30L mother.
    Chris there is a thread regarding long range tanks, I think if you want someone with experience with a larger tank on a WR250 you maybe stretching it as bigger tanks normally are for long miles and the WR250 wouldn’t normally be the bike of choice, you will have to pioneer the way!
    5L bum tank would stretch you out to 200kms with the bike geared right and that would be heaps on a little 250 and that seat and like ECKS said you can take it of, only leaves two 6mm holes :ohmy: , two rubber grommets from Supercheap can fix that ;)
    Sorry both my 17L and 28L are clarke.
    There is definately a long-range tank out there, ut for the life of me I can’t remember who makes the things! I’ll get back to you.
    In the meantime check out http://www.nomadtanks.com.au/
    #118005
    Ah ha! A Safari tank exists for the WR250F which is about 15.5 litres and costs about $449 or so (probably about $500 with delivery). http://www.rvaqualine.com.au/page.php?sId=3
    Knew I’d figure it out eventually! :P
    #118007
    I Like the Clarke tank at 13.6L $220 odd U.S, I’ll look for a AUS supplier and see how much it is.
