Home › Forums › Do It Yourself Videos, Photo Posts Helpful Hints › Do It Yourself Videos, Photo Posts Helpful Hints › Air filter mess free oil drainer !!
This topic contains 24 replies, has 0 voices, and was last updated by dennis da menace 12 years, 10 months ago.
May 7, 2013 at 9:48 am #102724
I use Motul air filter oil and no matter how much I squeeze out the excess after oiling I still end up with it running out of my air box drain and all over my swing arm and linkage. Its not cheap stuff and I’d rather not waste it. I’m not sure if its only my issue but here’s my solution.
I bought a 10ltr bucket with lid from the hardware store for $12 and poured in my 1ltr of Motul air filter oil.
I drilled a 10mm hole in the centre of the lid and got Spud to weld a 10mm threaded rod to a piece of 10mm bar to go through the lid.
Once the filter is oiled out of the bucket I squeeze out as much as possible then pass the t-bar through the filter.
Then put the rod through the lid and washer and screw down the nut.
Clip the lid onto the bucket to keep out dirt etc and leave to drain any excess oil back into the fresh oil.
I realize not all filters have a centre hole but I’m sure a similar method could be used on your filter with a few adjustments.
Note:
The air filter pictured hasn’t been fully oiled as I rarely use this filter.May 7, 2013 at 10:33 am #241379Hey Nick!
Bloody great idea Champ! You are definately a thinker :blink:
I hate wasting Motul filter oil too…… :dry:
Great stuff mate
Cheers, Left
May 7, 2013 at 10:42 am #241386I want one. Good job mate.
May 7, 2013 at 10:44 am #241389singletrackmind wrote:I want one. Good job mate.STM
I’ll make you one for a home brew longneck !!
May 7, 2013 at 11:04 am #241391Nickj wrote:singletrackmind wrote:I want one. Good job mate.STM
Sh#t that home brew must be good Nick :silly: :laugh: :laugh:
May 7, 2013 at 11:11 am #241380A plastic bag of some description and a cable tie , or tie wire
Loosely tie the wire or cable tie around the bottom of the bag or a quarter of the way up and this holds the filter up , hang it from something and all excess oil drains to the bottom
Or for the tightarses redirect excess oil from air box to your chain………….. :whistle:
May 7, 2013 at 11:20 am #241392Nickj wrote:singletrackmind wrote:I want one. Good job mate.STM
I will throw in a feed of slow cooked pork ribs and a night in the guest room.
May 7, 2013 at 11:28 am #241397Bob wrote:A plastic bag of some description and a cable tie , or tie wireLoosely tie the wire or cable tie around the bottom of the bag or a quarter of the way up and this holds the filter up , hang it from something and all excess oil drains to the bottom
Tried this and ended up with a sticky bag with a bit of oil in the bottom , then what ? Tip it back in the bottle ? Try to re oil a filter in the bag that’s sticking together ?
I ended up in a mess with the bag which is why I went the bucket , seems ok so far but I can seem to get that filter oil stuck to everything so time will tell !!
May 7, 2013 at 11:33 am #241403Nickj wrote:Bob wrote:A plastic bag of some description and a cable tie , or tie wireLoosely tie the wire or cable tie around the bottom of the bag or a quarter of the way up and this holds the filter up , hang it from something and all excess oil drains to the bottom
Tried this and ended up with a sticky bag with a bit of oil in the bottom , then what ? Tip it back in the bottle ? Try to re oil a filter in the bag that’s sticking together ? leave it a while and drain it in the bottle or oil another filter with excess , if you use decent bags
i oil all my filters in plastic bags …. No need for gloves
May 7, 2013 at 11:47 am #241404Bob wrote:Nickj wrote:Bob wrote:A plastic bag of some description and a cable tie , or tie wireLoosely tie the wire or cable tie around the bottom of the bag or a quarter of the way up and this holds the filter up , hang it from something and all excess oil drains to the bottom
Didn’t work for me Bob , sh#t stuck all over the bags in no time !
May 7, 2013 at 10:07 pm #241405Why bother with all that fuss? :huh:
I just buy a can of filter spray oil and spray it on :silly: job done
I watched Moto oil his filter in a plastic bag before we went out the other day and it was a messy business :blink:
But I do agree with Lefty, you are a thinker Nick
May 7, 2013 at 11:28 pm #241381http://www.youtube.com/watch?v=QR6pGeF-Zw4
Just another way of doing it. I usually do it this way and don’t waste any.
But your bucket set up is pretty trick.
May 8, 2013 at 1:36 am #241410Hey Nick. Don’t forget to wash the degreaser out fully.
If the degreaser or kerro or bundy or what ever you use to get the old filter oil off, isn’t washed off completely, it will make the new oil run off and not stick to the filter as well.May 8, 2013 at 3:18 am #241414gavb wrote:Hey Nick. Don’t forget to wash the degreaser out fully.
If the degreaser or kerro or bundy or what ever you use to get the old filter oil off, isn’t washed off completely, it will make the new oil run off and not stick to the filter as well.I use Leftys filter cleaner kit then wash out with warm soapy water. Once it’s dry it goes in my shed tumble drier to knock out any fine dust that may be left.
You get pretty fussy cleaning air filter when owning a crf250
May 8, 2013 at 3:37 am #241419Nickj wrote:I use Leftys filter cleaner kit then wash out with warm soapy water. Once it’s dry it goes in my shed tumble drier to knock out any fine dust that may be left.You get pretty fussy cleaning air filter when owning a crf250
Looks like you have got it sussed Nick.
I reckon when you put the filter in and the cage compresses the foam onto the lip of the airbox you will still get some seepage but not as much as before.
Lately I have been using Silkolene, it goes on very runny like water (which makes it easier to apply and less messy) and it dries nice and tacky like the Motul stuff.
