Home › Forums › General Bike Talk › Alloy Throttle Tubes
This topic contains 52 replies, has 0 voices, and was last updated by David 13 years, 11 months ago.
February 22, 2009 at 4:02 pm #95918
AnonymousWhat is the advantage of an alloy throttle tube over the standard plastic OEM tube.
February 22, 2009 at 8:38 pm #123370No idea, I had one on the 300 when I bought it, but binned it, as you can fit Barkbusters with alloy tubes.
I found out later you can get an adapter so you can fit the barkbusters, but it worked out cheaper and easier to just replace the tube with a plastic one.
February 22, 2009 at 9:04 pm #123376you can twist em fully sick hard and they dont break
February 22, 2009 at 9:05 pm #123377you can cash them in with your cans for Rum money :laugh:
February 22, 2009 at 10:14 pm #123378I put one on the WR as the plastic one had cracked, to fit barkbusters you only have to cut the end of the tube off,
pretty simple really;)ollie
February 23, 2009 at 2:08 am #123387Ollie wrote:
Quote:I put one on the WR as the plastic one had cracked, to fit barkbusters you only have to cut the end of the tube off,
so it still works obviously without the bearing for support ?
February 23, 2009 at 2:17 am #123425The alloy tube I have on the wr is the non bearing type,basicly the same as the plastic job only metal,the bearing one was an extra $30:blink:
February 23, 2009 at 3:17 am #123427
AnonymousI may have been pursuaded to try an alloy one with the bearings fitted to see if it runs smoother, but I wouldn’t bother with an alloy replacement, end cut off or not.
February 23, 2009 at 3:34 am #123431Moto wrote:
Quote:I may have been pursuaded to try an alloy one with the bearings fitted to see if it runs smoother, but I wouldn’t bother with an alloy replacement, end cut off or not.I have a brand new one to suit a EXC Kato at home.Dunno if it has bearings or not, but at $99 it bloody well should have.
February 23, 2009 at 4:05 am #123371
AnonymousMy conclusion from reading these replies is that there is no real advantage over the standard one, but if you need to replace a damaged plastic tube, then maybe do a price comparison and see if it is worthwhile to get a stronger design in alloy over a plastic design.
Why you would need bearings in a tube, I have got no idea. Just sounds like a marketing ploy. Bearings just add more weight and maybe potential to fail and sieze if contiminated with water, dust and blood (added for dramatic effect). Just how smooth do you really need a throttle to be??
My standard plastic tube is very smooth,and allows me to snap the throttle to “wide open” without a problem. I may even replace the throttle with an on/off switch as I ride with it pinned to the stop all the time anyway. I am a really good rider! Just ask me.
Thanks all for the replies.
Slug
ps there isn’t even any bling value with an alloy tube as you can’t even see it.
February 23, 2009 at 4:40 am #123441slug wrote:
Quote:My conclusion from reading these replies is that there is no real advantage over the standard one, but if you need to replace a damaged plastic tube, then maybe do a price comparison and see if it is worthwhile to get a stronger design in alloy over a plastic design.Why you would need bearings in a tube, I have got no idea. Just sounds like a marketing ploy. Bearings just add more weight and maybe potential to fail and sieze if contiminated with water, dust and blood (added for dramatic effect). Just how smooth do you really need a throttle to be??
Slug
and the FIGJAM award goes to
Slugps there isn’t even any bling value with an alloy tube as you can’t even see it
February 23, 2009 at 11:25 am #123444Alloy throttle tubes are there only to stop breakages that then jam dirt into the tube and bar at full or partial throttle openings, a very unlikely event but a nasty one if it does happen, with an enclosed end in metal it is impossible for the dirt to jam it on, No Bling Bling Here just practicality
February 23, 2009 at 11:27 am #123525Choppers plastic OEM one feels funny on the carbon fibre bars, it has a funny feel when it rotates on the bars
February 23, 2009 at 11:30 am #123526is that the fibre that sticks up in the weave??
February 23, 2009 at 11:47 am #123527Maybe I dont know havent looked :laugh: just noted when I didnt the 600 odd kays that weekend with Moto, Boulder and Tiny
