Alloy Throttle Tubes
Home Forums General Bike Talk Alloy Throttle Tubes
This topic contains 52 replies, has 0 voices, and was last updated by  David 13 years, 11 months ago.
Viewing 15 posts - 16 through 30 (of 53 total)
  • #123528
    Paul
    I suppose if the bike is dropped, an alloy tube could bend or kink and bugger up the throttle movement.
    Plastic might self recover better :unsure:
    #123531
    Hush yo mouth Wikd. I have a new one here for a KTM I want to sell..LOL
    #123533
    Oh and buying things from you is always a good move trust me :blink: Honest Mick Sales :silly: lol
    #123532
    No Mate you have it backwards, the plastic will tear and bend then let dirt into the tube, the billet alloy wont do that and if it does get enough force into it to make it kink, you wont be riding more than likely, well you will be riding….an ambulance to the hospital….or if you are real lucky a helicopter…..lets hope that never happens hey
    #123537
    Wanna buy a Wirtz alloy throttle tube Dave?
    #123538
    I had an alloy billet closed throttle tube on an XR600 a couple of years ago, it was a ballards one with a bearing in it, it came on the bike when I bought it 2nd hand, anyways it fell of the stand on a hillside and bent it and jammed and was no good anymore :dry: So I fitted bark busters a plastic one and no dramas anymore, need B/B to protect the ends I reckon
    Looks like I am wrong again Mate, stick with the plastic you will have no dramas….sorry Mick I tried…..and yes TB I have of heard this before, and a mate of mine solved it by running the tube a little further out on the end of the bar, but my own bike has the standard plastic because I too run Barjbuster’s, I meant Barkbuster, but its the same same to me
    #123544
    Mines worn really thin on my 650 Dave, its plastic, I may switch to an alloy with the end trimmed for the bark buster, I loved the alloy one it was very smooth but must have been the angle of the dangle when it fell over, but can I still run the bearing and B/B dave?
    Yes TB I am sure you could linish(sp??) the end off really neat to enable the alloy tube to be used
    #123546
    Paul
    It must be like a thrust bearing in the end of the tube?
    Maybe a bearing shop will have a thrust bearing with a hole big enough to accept the Barjbuster mount thingy?
    Nah! Too many moving parts that can fail or fill up with mud and go rusty me thinks.
    #123372
    my 2 pesos
    I am concerned about aluminium throttle tubes:
    about the handlebars flexing and the throttle tube not,
    plastic can be a much better bearing material than aluminium
    the plastic can flex and hold on the bar while aluminium will always be a clearance fit in correct circumstances (without bearings)
    bearings will also be concentrating the stresses, which could cause the bar to break at the bearing mount
    saying all this, they have probably been used for years without problem
    #123547
    The one I have had for a year now hasn’t given me an ounce of trouble. It is still in it’s original wrapper hanging on a hook in my shed!! LOL
    It is for sale for what I paid for it, from Coastal KTM..$99.95
    Or will swap for an appropriate amount of alcohol.:laugh:
    #123548
    I think we’ve arrived at the fact that there isn’t much point in buying an Aluminium one and Mick is stuck with the one he bought :laugh:
    #123551
    Give you $50 bucks for it, not that I really want it, but will buy it and use it and just to see you take a loss, 50 is better than nothing
    Hey, you’re online….and on a schoolday!
    What do you want with a KTM throttle tube?
