Alloy welding
Home Forums Tech Help Tech Help Alloy welding
This topic contains 14 replies, has 0 voices, and was last updated by  Eric Smith 16 years, 7 months ago.
  • #97059
    Need some alloy welded on my hussky its got two broken exhaust mounts on rear sub frame where the muffler bolts up. does any body no a good alloy welder in sydney.
    #149874
    Hi Tiny,
    Nar sorry, i’m not in Sydney, or even near it.:blush:
    check out Austbules “sump plug won’t seal” thread.
    TB put him onto a top bloke that dose all that.
    if not look up yellow/white pages and look for and engineering shop and ask if they have a tig.
    Greg Ball -Motorcycle Engineers
    (02) 9521 8470S
    Unit 20/ 4 Ethell Rd Kirrawee
    #149880
    Hey Tiny I know one,really good rate as well,but others have said his welding looks like cocky shit,so I cant recommend him:(
    Yeah sorry Ollie but that is the worst welding job of any material / metal I have ever seen, ever I reckon you got nuts putting the picture on the site :laugh:
    A job like that any welder should be able to handle, the bike shops would know one in town Tiny
    Thanks fellers mite try S&R pro just thought mite see wot you blokes could come up with but all is good:kiss:
    #149908
    The sad part is I am a qualified first class welder and I thought it was pretty good:unsure: But hey what would I know:laugh:
    So you thought it was ok then?
    yep,but more importantly so did the customerB)
    Can you let us how much it costs to get done Tiny when you sort it please?
    #149875
    Scott
    I have always used Micks Metal Craft in Kings Park. 9755 7137
    Melissa Av kings Park next to Pirtek. He’s not the cheapest around but IMO his weld quality is pretty awesome.
    #150002
    There you go Tiny. Kings Park is near Blacktown isn’t it?? Kinda near you.
    #149975
    i could be totally guessing here Moto, but when am i not:S :laugh:
    to do 2 muffler mounts should not be any more than an hours work, so should only be the rate the guy charges for per hour.
    tig/ alloy filler costs/charged at about $1 per stick if bought individually , i don’t know if they charge for argon? i doubt they could work it out per litre so would be factored into the hourly rate.
    at the outside most, it would not take anymore than 3 sticks of filler wire, if it is just cracked/ broken off.
    if you clean all the spots well to be welded with stainless wool, you usually use a stainless wire brush to knock the oxide off the alloy, they will only have to weld it.
    cleaning takes more time than the actual welding it’s self.
    as usual i hope this helps but replies/time will only tell:huh:
    #150010
    Thank you XY I know you intended to help :)
    What I am after is the actual cost to do the job though, I can make a guess as good as the next guy based on the invoices I used to get daily from the welders and boilermakers I used to subcontract :)
    The thing is welders all charge different rates so guessing an hourly rate, whilst it may be close isn’t what I’m after. The guy TB uses seems very cheap and TB swears by his quality.
    Don’t take this as a moan, it’s good that you have taken the time and bothered to reply, I’m just a miserable old bas**rd :laugh:
    Since you’ve been so good I’ll change you rank back to normal now :P
    #149876
    jamie
    Tiny
    Mines cracked at muffler mounts also,must be a husky trait. But has copped some decent hits there.
    An exhuast shop might be the go, ]a lot of them are into cars etc and might have the right gear.
    cheers
    #150043
    Dave’s Husky 610 did the same at the end of the Safari. Who woulda thunk that 3800km of racing would cause anything to break? :laugh:
    Dave uses a local guy in Orange for alloy welding, did a mickey mouse job on the custom bash plate water tank. If anyone is interested I can get the details for you. Long trip for a small job though!
