And so the mid-life crisis begins …
Home Forums Your Garage And so the mid-life crisis begins …
This topic contains 49 replies, has 0 voices, and was last updated by  Darren 13 years, 8 months ago.
Viewing 15 posts - 31 through 45 (of 50 total)
  • #225814
    Darren
    moto wrote:
    I’m surprised Mick can work a computer, they were only invented in Wauchope 2 years ago :P Nice ride by the way Razzle. I have a 2012 Berg and had a KTM300 so I know the fun you’ll have :)
    Thanks, sooooooooo looking forward to it … can’t bloody wait!! :woohoo: :woohoo:
    #225819
    [attachment=3486]c64Small.jpg[/attachment]
    #225821
    Ahhhhhh the memories..!!
    #225820
    Darren
    BTW: it was called a “Datasette”
    #225807
    Them boots are as gay as snowys new white ones, and dont worry about anyone laughing at you, we laugh at mick all the time and he gets over it.
    ian
    pete the wulf wrote:
    Hey smokey you have white boots cause your a raging homo :P :P :laugh:
    its only when i wear the boots alone and nuthin else on the honda people question that ptw ( now theres athought that willl stick in your head )
    #225822
    where’s the any key? and the liquid paper on the screen?
    :whistle: :pinch: :P
    #225828
    it’s their xy maybe your not blonde enough 😆 😆
    #225830
    You pack of arses!! :) Not only have you spent the evening taking the piss out of me, you have trashed Razzle’s Garage thread. :ohmy:
    Razzle, “Forgive them, for they know not what they do.” (famous quote from a bloke with a beard and sandles).
    Thanks for all the nice comments guys, lucky I have broad shoulders. :laugh:
    #225837
    Darren
    Thanks Mick, never mind re trashing my garage thread … I’m still chuckling about the Elton John comment and the red wine in the keyboard incident.
    Purchase number two arrived today :)
    The bike hasn’t even arrived and already I’m modding it!
    #225872
    Steve Wyeth
    There are many jettings pecs available for the bike that work as a good baseline and every bit as well as the (or better) than the JD kit. Ah well, have a play with that and have fun, it will be an improvement over stock as they are delivered rich and blubbery from the factory.
    If you have any other set-up questions feel free to ask, I spent alot of fiddliing with my 300 to get it just right and may be able to save you from a bum steer in the future :)
    #225875
    Darren
    Yep, it’s a start.
    The advice I got was from some mates in Sydney with 300’s. Reckon they got smother power delivery and most importantly better fuel economy out of the JD kit. All the reading I’ve done so far has said they run rich from stock, so I’ll run it in with the stock setup, then swap to the JD.
    Thanks for the set-up assistance offer, might take you up on it
    #225838
    We did wait for you to logoff mick I thought that was nice, and yes Razzle sincere apologies for hijacking your thread it won’t happen again unless I’m drunk :ohmy:
    #225880
    Steve Wyeth
    Here is a spiel I posted on another forum, sorry for the long post here but including a link to other site would have not been politically correct! Since your bike runs all the same parts as the KTM from >08 onwards all the specs are valid:
    A massive part of getting your KTM 2 Banger to work, and work well, is based around the jetting. I have played extensively with this since owning my 300 and have also researched a lot to broaden my own knowledge on how to jet the bike.
    There are heaps of jetting charts, tables and descriptions on the net that tell you how the relationship between the different circuits react, so I won’t go into that detail there. It should also be noted that there are other factors that effect how your bike feels, such as gearing, map switch setting, power valve settings/springs not to mention personal preference.
    Here is my guide to what I have found, researched and tested. This will act as a crib sheet to help me as much as anyone else!
    Needle Types
    The standard needles are dual taper and have a longer initial taper due to their steep angle making it much richer in 1/8th to 1/4 throttle area. The second taper on both needles are the same angle but the taper starts earlier on the NExx series needles. The N2xx series needles second taper then continues to the end of the needle, where as the NExx series needles have an even steeper third taper to bring more fuel in the mid to full throttle positions.
    The result of these differing tapers means that the N3xx/N8xx/N2xx series needles are richer 1/8th to 1/4 throttle and leaner from about 1/3rd throttle onwards compared to the NExx series.
    This tends to make people lower the N3xx/N8xx/N2xx series needle clip position too far to gain a clean low opening throttle response and, worse still, leaning the pilot out to compensate which will kill proper throttle response.
    Running the needle in a lean clip position to clean up the low throttle will lean out the rest of the throttle making the bike more difficult to ride in all but flat open terrain. As I know from riding my 450 4 banger, traction and controllability is how you need your power to feed in. Super snappy 2t power is fun but is much harder to hook-up.
    So that it is easy to understand the stanadard needles and their relationship to each other I have listed them in an order of sorts.
    These are the standard needle codes in order from lean to rich in 1/2 clip increments. The exception is the N3CJ which is a full clip leaner than the N8RJ (from 1/4 to full throttle the needles are all the same):
    N3CJ
    N8RJ
    N2ZJ
    N8RW
    N2ZW
    N8RH
    So, as mentioned above it is widely regarded that limited success can be had with the standard needles unless the carbie slide is changed to compensate for the disparity in the standard needle tapers. Cue the Suzuki needles!
    There has been a lot of talk and testing happening in the states where triple taper Suzuki needles are being used with the stock Keihin PWK 36mm slide. The taper of the needles is such that we are able to provide a richer initial taper, meaning no off idle lean bog or 1/8th throttle stutter, whilst still achieving proper fueling over the rest of the needle. The result is super smooth torque and power right off idle to full throttle.
    The specific needles being tried are from a 2004-2008 Suzuki RM250. Again for ease of reference and understanding of which needle is rich or lean they are listed below from rich to lean in 1/2 clip increments:
    NECF
    NEDF
    NECG
    NEDG
    NECH
    NEDH
    NECW (‘W’ is substituted for ‘I’)
    NEDW (‘W’ is substituted for ‘I’)
    NECJ Part Number 13383-37FE0
    NEDJ
    NECK
    NEDK
    NECL
    NEDL
    Needle Diameters, again, rich to lean.
    NECF/NEDF 2.705
    NECG/NEDG 2.715
    NECH/NEDH 2.725
    NECW/NEDW 2.735
    NEDJ 2.745
    NECJ 2.745
    NECK/NEDK 2.755
    NECL/NEDL 2.765
    NECJ and NEDJ have been reported to be a big improvement over any of the standard needles by a number of people both in the US and Australia.
    For a 250 the NECW and NEDW needles are reportedly the ones to try. Always start from clip 3 and with your air screw 1.5 turns out and go up/down as required. If you have to go to 1/2 turn out on the air screw you need a bigger pilot jet, more than 2.5 turns out and you need a smaller jet.
    As a result of the different profile of the Suzuki type triple taper needle it is likely required for best results that you will need to drop one size on the main jet (due to the third taper not being present on the stock dual taper needles). The current set of testers have also preferred a 38 pilot jet over the stock 35 as it feels more ‘torquey’, this is however, subjective so you should try both out for yourself and see what you prefer.
    Power Valve Springs
    The other thing that can dramatically effect how your engine delivers it’s power is playing with the power valve springs and the brass, square drive, preload screw. Contrary to popular belief the PV springs and even the preload adjuster do not alter the point at which the PV starts to open. This always occurs at approximately 5,500RPM.
    The colored spring supplied provides different rates of tension to offer a resisting force to the power valve opening. What they do control is the RPM range that the PV starts to open until the point it’s fully open. Below I have listed the spring from fastest to slowest opening and the RPM in which they are effective:
    Red 5500 RPM – 7400 RPM
    Blue (optional)
    Yellow 5500 RPM – 7800 RPM
    Green 5500 RPM – 8300 RPM
    So, you can see that the Red spring allows the bike to be at full power sooner in the RPM range than the other springs. This is why it’s often referred to as the ‘aggressive’ spring. I disagree with this statement and find it to be the most linear set-up as you have full power sooner.
    Through my own testing I have found that it can be aggressive when running a lean stock needle as this really saps the low end power/torque of the bike, so when the the PV does come in the ‘hit’ feels much more pronounced.
    Also the hit comes from the PV allowing full power when fully open, so the Yellow and Green springs keep the bike tamer for longer but then transition quickly to where all the power is which results in a bigger ‘hit’ in my opinion. Again, all personal preference but give it a try, you might like it!
    #225892
    Darren
    Whoa! That’s a whole lot info … thanks. :)
    Saved it off for later reference.
    Any tips on suspension setup … 72kgs 5 foot 9″ rider ?
