Home › Forums › Product Reviews › Product Reviews › Asterisk Knee Braces
This topic contains 18 replies, has 0 voices, and was last updated by Dean 17 years, 6 months ago.
July 2, 2008 at 11:21 pm #94861
Firstly I have never had a serious knee injury but was always aware the stress our sport puts on your knees, I am a big guy and thus when riding for long periods I find my knees suffer e.g. 4 day 2006 I was struggling of a morning with my knees being so sore, I know braces wont stop that but its an eye opener as to how bad it could be to have a knee injury. Add to the pain, the time of work and the financial stress most of us would be under to be laid up for three months or so.
I started looking around at braces, I spent months talking to people that wear braces, checking on the net reading reports, punters opinions, experts thoughts and so called experts thoughts. I found that I could spend anything from $190.00 to $2000.00 a leg on braces. Some brace companies custom make the braces for you and would refit them should you lose / gain weight etc over the years!
I settled on the Asterisk Knee Braces, I priced them all over Australia and the best price I could get was $1150.00 for the set. I then priced them overseas and purchased them for $635.00 for the pair, freight was $65 which included a new Bell helmet so I was still about $500.00 in front.
They are fiddly to set up the first time, I did it at home with a Bundy Rum and had no dramas, there are a lot of adjustments but once its done you shouldn’t have to do it again.
The first ride I wore them I thought this will be interesting, expecting them to rub or have some breaking in / discomfort. Once on the bike I noticed that gripping the tank was very different easier a lot easier, my legs felt strangely wider apart than before but I quickly adjusted to it or put it out of my mind. The ride turned out to be a shit fight in that we got bogged and did our own mini erzberg enduro, it was during this walking pushing dragging I thought I have knee braces on! Yes they are that comfortable, I had to mentally remind myself. At the end of the ride I looked for marks on my legs that may have shown rubbing etc but nothing. I am very happy with the Asterisk knee braces being that they aren’t the $2000 a leg jobs I believe them to be the best of the shelf fit braces. Now that I am old (my kids say so anyway) I am looking to do everything as I always have but realize that I am not bullet proof and some extra protection is the go.
Attached are some of the details regarding the braces.
Advanced Strength Carbon Fibber Technology:
Carbon fibber injection melding process creates a strong, lightweight, rigid structure to help withstand forces and protect the knee. Ergonomically designed frame for an improved intimate feel for the bike.Telescoping Patella Cup:
This special design will cover the kneecap area in a straight leg position and in a bent position including coverage of the areas above and below the kneecap.Oblique Axial-Free Motion Hinge
The only hinge ever developed that can contour the inside of a leg at an oblique angle to the outside hinge. This allows for a low profile fit. Simulates the natural knee motion of flexion (bending) and extension (straightening) and automatically aligns /locates /positions /the tibia (shin bone) for a proper fit. Prevents slipping and positioning of the frames on the leg and has a “free” non-restrictive motion. Auto aligning allows for the frame to automatically locate the correct angle of the user’s lower leg.
Lace-Linear Buckle System
Lace linear for secure comfortable fit. Prevents “roping” across the muscles securing the frame to the leg comfortably. Provides increased protection and eliminates slipping. No stretch laces glide through abrasion resistant lace loops for even distribution and a comforting fit. Single fibber quick release.
Adaptable Tendon Cuff:
Attaches to the upper and lower frame wrapping the thigh and calf. Special tendon stripes retain stiffness at adjusted positions to maintain structural integrity for increased support and protection.Thermo-Formed Padding Interface:
Thermo-formed for intimate frame and cuff fit. Increases impact resistance. Self cantering tibia padding design for shin alignment and comfort.
Features
• A.C.M. Frame
• Anatomically correct design
• Carbon Fibber Epoxy Matrix
• Rigid & Lightweight, Impact-Distributing structure
• Asymmetry-Glide Hinge
• Tracks the natural “rolling-gliding” motion of the knee joint
• Asymmetrical design allows each hinge to set properly at the knee joint
• Adjustable ext. regulator from 0° to 40°
• Uni-Quad Fastener
• One knot, Four adjustment zones
• “Hyper X” lacing pattern links zones 2& 3 for optimum extension resistance
• Eliminates brace slippage
• Distributes pressure evenly to the back of the leg
• Superior security to strapping
• Tele-Tri Patella Cup
• Telescoping Three piece design
• High impact Nylon 6 material
• Full range of motion overage of the knee cap
• Thermo-Formed EV50 shock absorbent foam padding
• Thermo-Formed Padding
• Thermo-Formed for precise A.C.M Frame and A.R.C Cuff fit
• Forms to leg shape using your body heat
• Two sizes of join pads for individual adjustment
• A.R.C. Cuff
• Adjustable Retention Control
• Multiform rigid lateral support
• Customizes to leg shape and size
• Quick Release Buckles
• Single finger quick release
• Low profile
• Water Resistant
• Non-corrosive metals
• Non-corrosive composites
• Hand washable soft materials
• Anti-Rotation Tether
• Links the brace to the boot, making them as one
• Transfer forces of a lower leg rotation and disperses them into the upper A.R.C. Cuff
• Adjustable to suit each individual
• Undersleeves
• Conically tapered cut to match the legs natural contour
• Ventilated mesh promotes air flow
• Reduces heat build up by wicking moisture away from skin
• Flat stitched quad seam for a smooth, durable finish
• Durable fold-over elastic bandJuly 3, 2008 at 12:25 am #105090TB, great review, maybe one day, with the current state of my knee could be sooner rather than later.
July 3, 2008 at 10:38 am #105094Good job TB, did you buy them from the US, you didnt say where overseas?
July 7, 2008 at 9:38 pm #105091I think I,d like to get myself a set of those too,, good bit of info there TB
July 7, 2008 at 9:41 pm #105245BTO motorsports, or giant motorcross in the states champ around $630 + freight australia $1195.00
July 8, 2008 at 5:35 am #105247Gidday all…..I buy all my parts and gear from the states and have saved thousands check this site out,cheap,good service and quick delivery…have a look at there closeout deals http://www.rockymountainatv.com
July 8, 2008 at 6:43 am #105092Another good place to get genuine Parts for your Jap bike is http://www.jp-parts.com
I have used them plenty of times and found the service excellent and I save about 50% on the cost of parts from the local stealership. The website is in english and the owner speaks good English as well.
They have a special that runs all the time, $124 for genuine two stroke piston kits delivered to your door.September 25, 2008 at 9:38 am #105093
AnonymousDo you wear the braces on EVERY ride, or just when you think it may be a tough ride?
N
September 25, 2008 at 12:55 pm #108601wr450fs wrote:
Quote:Do you wear the braces on EVERY ride, or just when you think it may be a tough ride?N
Every ride, they take less than a minute to put on and I dont know which ride I may wrench my knee do I ?
September 25, 2008 at 1:44 pm #108609Good review Greg,they are high on the list of thing’s I should aquire…………..ahhhhhhh so many thing’s to get and so little money,trust me you guy’s when I say if you have ever had ligament or tendon damage to your joints they make a broken bone look appealing strange as that sounds I reckon it’s the truth as the bloody thing’s ache and creak all the time.
Greg was it hard to work out the sizing,I would worry that they would not fit me and then would have to dick around returning them to the states and such.
Gee’s they would be handy for the ride this weekend……been told that there will be a minimum of 35 bikes going that’s just great:dry: what’s the chances of it being a trouble free affair;) ,I might stay at the pub with no beer and see if it is true:laugh: .PS, sexxxxxxxy legs mate:laugh: :laugh:
Regards Chris.
September 25, 2008 at 7:23 pm #108610Chris.T wrote:
Quote:Gee’s they would be handy for the ride this weekend……been told that there will be a minimum of 35 bikes going that’s just great:dry: what’s the chances of it being a trouble free affair;) ,I might stay at the pub with no beer and see if it is true:laugh: .PS, sexxxxxxxy legs mate:laugh: :laugh:
Regards Chris.
Where are you riding this weekend Chris and who is organising it? If there is that many riders going, maybe you could print a few OLD Bull flyers from the home page and pass them about??
September 25, 2008 at 9:39 pm #108611No problem,now where is the section to print the flyer’s from.
Regards Chris.
September 25, 2008 at 9:55 pm #108612
AnonymousChris.T wrote:
Quote:No problem,now where is the section to print the flyer’s from.Regards Chris.
Front page, home page, to the right of the santa claus picture, marked get this, get this, old bull flyers! (where to you guys come from really)
Oh and you Chris T cant wait till I have time to sort you out, Head Lines scoop read all about it.
Burnt out old never was, trys to be!
CYA later dudes I have to go, so many babes so little of me
September 25, 2008 at 9:55 pm #108613On the home page just to the right of Santa…
September 26, 2008 at 1:36 am #108616Thank’s for the direction’s,should have known that it would be next to the santa claus(where else would it be).
Squirrel,squirrel,squirrel you silly little fellow,so much promise,and I would have been worried about being sorted out except for this admission by yourself “so many babes so little of me” now squirrel we all know the story about the guy with the little one.I bet there are some dissapointed babe’s ehh but I need people to make me look good with the babe’s, and for that I thank you;),oh what it must be like to be a gerbil:P
:laugh: .Chris.
