Attaching Alloy Case Guards
Home Forums General Bike Talk Attaching Alloy Case Guards
This topic contains 6 replies, has 0 voices, and was last updated by  Greg 14 years, 7 months ago.
  • #100139
    Ok,
    So I have some nice Alloy Case Guards on the way for the 690 courtesy of Steve at AdvMoto.
    Question is, How much Hi Temp silicone do I need to keep them on the cases, but not have to smash the bejeesus out of anything should I need to get hem off ????? :whistle:
    I guess two or three decent dobs on each should do it, then I was planning on a small bead around the edges to keep mud & grit out from between the two,,,,, I would also leave a small gap at the bottom of the bead to let any moisture out if it does get in,,,,
    Any other suggestions ????????????
    #204346
    What about two or three decent dobs on each, then a small bead around the edges to keep mud & grit out from between the two,,,,, then leave a small gap at the bottom of the bead to let any moisture out if it does get in,,,,
    So, I answered my own damn question I take it ????? :whistle:
    Thanx for that :laugh:
    #204348
    If that doesn’t work Eags can I suggest two or three decent dobs on each, then a small bead around the edges to keep mud & grit out from between the two,,,,, then leave a small gap at the bottom of the bead to let any moisture out if it does get in,
    #204350
    I just think great minds think a like Eags :laugh:
    Seriously you have it down pat I reckon, hadn’t thought of the hole in the bottom do drain moisture nice job
    Actually that’s a better idea than ours Eags, good thinking Scotty ;)
    Do that Eags, do it, do it ;)
    #204349
    Comedians everywhere B)
    :P :P :P
