BACK ON.
Home Forums General Bike Talk BACK ON.
This topic contains 5 replies, has 0 voices, and was last updated by  Mick D 17 years ago.
  • #96053
    JCW 250F
    hey boyz im back on. my computer died & ive only just got it fixed.had a great time at the wauchope ride cant wait to go on another 1. u got some go pics of the day. just wondering me new wr has been playen up a bit its been coughen & spluterin every now & then.think it gettin water in it when i wash it has any 1 else had any probs.
    #126393
    Jason,
    when does it normally sputter? When idling? half throttle? full throttle? varying throttle? constant throttle?
    I doubt it is water but maybe drain the fuelbowl as a precaution using the small brass screw on the rear LHS of the carby.
    I’d say it could either be the TPS (throttle position sensor) or the jetting of the carby. The WR is known to sometimes sputter when held at constant throttle, such as riding on the road. You can disconnect the TPS connector at the carby and see if that makes a difference.
    One thing to be aware of with the WR and cleaning it, is that water can get into the spark plug cavity and rust the outside of the plug. Once you finish washing the bike, lean it over on the RHS so any water can drain from the tiny hole in the head. Also, start and run the bike for a few minutes to evaporate any water around the plug. The rusty plug is really only an issue because when you remove it, rust scale may drop into the cylinder.
    #126395
    xr torcher
    Jason i will be water undo the 17 mm nut on the bottom of the carby drain some fuel out with the throttle held open it is a common problem from 07 with the new frame
    #126400
    How does the water get in, in regards to a different frame design?
    How can it be prevented?
    #126394
    JCW 250F
    yeah its really strange,it does it after bout 20kms & then it will clear its self after a minute.so i dont think that it is a big deal.it just gives me craps,it shouldnt do it.
    #126435
    I agree with riderX,drain your carby, I would suggest.
