backwoods yamaha
Home Forums Yamaha Bikes Yamaha Bikes backwoods yamaha
This topic contains 66 replies, has 0 voices, and was last updated by  Bruce Curtis 16 years, 6 months ago.
Viewing 15 posts - 16 through 30 (of 67 total)
  • #151882
    Its very impressive far more technically advanced then a KTM at the moment but I guess once you have the rear end worked out you can concentrate on the rest of the bike. So thats Honda, Susuki, Yamaha, Husaberg, Husky, Serco with fuel injection, who have I forgotten?
    The new 2010 CRF450X is injected I heard recently
    So’s the KTM supposed to be, I’ll believe that when I see it though. Either way, my next bike is very likely not to be a KTM. I think the other guys are moving ahead of them now and have better things to offer.
    #151951
    I like the new plastic rear subframes, very cool. Especially if like the Berg it can be modded to give you an extra couple of litres fuel capacity when needed.
    #151952
    it looks like square section aluminuim to me. i think the berg is a bit trickier there
    #151973
    Aluminum sub frames for me, alloy can be straightened and welded when repair time comes around. IMO
    i do think a 4 valve head is a good one yamaha ;)
    but i still think that valve heads are too big and heavy as far as i’m concerned though ;)
    #151978
    look betta in yellow
    #151980
    In regards to the twisted up exhaust, could they not alter the timing or fuel mixture or cam or something so they could use a shorter exhaust. I realise the length is for the torque and power curve etc, but with all this new technology i thought something could be done about it.
    #151983
    i think 1m of pipe works good for mx.
    i was also told a few weeks ago (from an undisclosed source) that they originally wrapped the pipe around the shock. but james stewart kept wreaking the pipe when the spring expanded radially. :dry:
    sounds sus to me. i think yamaha would have thought of that prior to putting their prize fighter on it
    #151984
    thats nice champo but not exactly an answer to my question
    #151791
    is it just me or dose it look 1/2 finished?!?!?!= pics 3->8 :blink:
    :laugh: :laugh: :laugh: :laugh:
    :P :P :P :P
    MMMM FI dirt bike MMM
    i too think the mid pipe looks a bit cumbersome, but must work or they would not have released the bike the way it is.
    #151988
    tuned pipe ?????? I agree with 4skin Y not try to match the engine mapping and the gasses removal system to give the desired result instead of that queer looking and I would say rather expensive exhaust pipe,,,yuk,,Dont like it at all. :angry:
    #151990
    that’s ok. you stick with your dr mate.
    i’ll stick with my expansion chamber
    #151993
    deal!!! I`de wait a few models If I was interesred just to let them iron out the bugs,
    #151997
    did tb just put up a post and remove it or did i fall asleep and dream it?
    anyway tb.
    springs compress, twist, do all sorts of flexing. and i’m told expandand radially
    shocks also pivot.
    thats why there is a gap between your spring and airboot
    #151999
    Are you expecting me to believe Champo that the spring is expanding outwards to the point it was touching the exhaust let alone damaging it? A spring compresses it doesnt blow outwards like a paper bag. I chinese bike one might :laugh:
    http://www.youtube.com/watch?v=7Rb4PERPM3U&feature=related
    Firstly the shock absorber would run out of stroke before the spring should, also the springs compresses it doesn’t expand outwards anywhere like that. My XR rear spring is so close to the intake boot I cant fit my little finger between it and it doesn’t touch with my fat arse bottoming the rear out from time to time. Lastly I would thing Bubba would have the best money suspension that money could buy including enough technicians to make sure he doesn’t have a rear shock spring that expanding outwards instead of compressing as it is supposed to. If the spring expanded instead of compressing anything like it would need to to damage the exhaust you couldnt control the compression rate of the spring. As the below video shows even with two tonnes force the springs still don’t blow out sideways bugger all
    http://www.youtube.com/watch?v=p07dGWQJMWk&feature=related
    Sorry but in mine opinion you undisclosed source is dreaming
