Home › Forums › General Bike Talk › Balls in your Tyres
This topic contains 22 replies, has 0 voices, and was last updated by Dean 15 years, 3 months ago.
February 2, 2010 at 9:10 am #98007
I sold some tyres to a regular customer today and we got onto the subject of tyre pressures. Mike said “I run Ze rear tyre at 0.8 Bar (with a true german accent :laugh: )and in Ze front I use Ze tennis balls!!” I said your joking, :blink: Nein Nein I get Ze used tennis balls from the local courts and stuff them in the front tyre” I have seen those tyre balls before but thought it was a bit weird to run”ZE Tennis Balls :laugh: ” anyway he swears by it. Might have to give it a go one day :laugh: anyone else done some weird shit like that?
February 2, 2010 at 9:17 am #170132I have seen these Ollie before, but they need to be greased to slip around the tyre and I cant work out how with tennis balls you could do that. They would chaff to pieces otherwise if you know what I mean like a dry mousse tube
But then if he runs retreads anything is possible I guess
Get some photos maybe :huh:
February 2, 2010 at 9:18 am #170133sounds like the old ZF fairlane rear suspension trick…let us know how it goes nipple, just dont ride new a tennis court :woohoo: :woohoo: :woohoo: :woohoo: :woohoo:
February 2, 2010 at 9:20 am #170138Boony wrote:
Quote:sounds like the old ZF fairlane rear suspension trick…let us know how it goes nipple, just dont ride new a tennis court :woohoo: :woohoo: :woohoo: :woohoo: :woohoo:C’MOOOOONNNNNN!!!
Ollie :laugh:
February 2, 2010 at 9:23 am #170139He said by the time it was time to replace the front tyre he had about 6 balls that had lost their pressure but were still working Ok. He doesnt even remove the green felt covering :dry:
February 2, 2010 at 9:32 am #170140wouldnt a tube be cheaper???????
spose its better than having tyres in your balls????
sorry
February 2, 2010 at 9:32 am #170141Ollie wrote:
Quote:He said by the time it was time to replace the front tyre he had about 6 balls that had lost their pressure but were still working Ok. He doesnt even remove the green felt covering :dry:Ollie
I still cant understand as a Mousse generates so much heat and needs lube?? You should try it Ollie, at least you cant pinch them or glue the patches on without removing the backing :laugh: :laugh: Very interesting but, and really if someone is cheap enough to run a retread tennis balls aren’t a stretch really eh?
Will watch this space be cheaper then a $200 mousse :laugh:
I saw a guy on a ride once try stuffing a rear tyre with dry grass, was very funny and didnt work :laugh:
February 2, 2010 at 9:58 am #170142This is worth a read, it gets fairly emotionally charged towards the end but is worth a look :laugh:
February 2, 2010 at 10:15 am #170143Bloody Yanks!! :blink: I give up after reading 6-7 paragraphs :laugh:
February 2, 2010 at 10:32 am #170134Tennis Balls ??????????
Got to be kidding :laugh:
What ever floats his boat, I really can`t see the point :blink:
We get sick of the things going flat after 2 set on a wed night at our local comp and we are far, far from Roger Federer style :laugh:
Interesting thread tough Nipples,,,, i mean Ollie
February 2, 2010 at 10:41 am #170135I might try some golf balls. I bet that would work great!
February 2, 2010 at 12:39 pm #170149chris72a wrote:
Quote:I might try some golf balls. I bet that would work great!Chris
Make sure you get some video of the first ride Chris.
Sounds interesting Ollie. Would be funny changing a trye at the A4DE and tennis balls flying out everywhere. :laugh:
Does Mike use any special type of tennis ball as stated in that link from TB. I only scanned through it as they seemed to lose the plot there somewhere.
February 2, 2010 at 11:57 pm #170178No Mal, but he did say that the used ones were better as they could be fitted into the tyre more easily. I personally believe that the tireballs that TB linked and Mousse tubes would do a better job,me I will stick to the UHD tubes and Slime to prevent flats. Mike tried the balls because he got two flats on the front in one ride.
December 2, 2010 at 8:30 am #17013610 months ago Ollie mentioned Tennis balls in your front tyre and I like everybody laughed at him.
Well a well known industry person today mentioned running tennis balls in the the front rather than a Mousse. I laughed but soon realised he was deadly serious :huh:
So to settle this I am thinking of trying it :blink: any input would be welcomed
December 2, 2010 at 8:51 am #191777Mike Ze German has come back several times and he is still using them,so they must be doing the job :laugh:
I have just purchased a set of Tubliss and will be interested to see how they go as well
