been fiddling again
Home Forums General Bike Talk been fiddling again
This topic contains 11 replies, has 0 voices, and was last updated by  Sean Ramsay 13 years, 11 months ago.
  • #101182
    Sean Ramsay
    hiya,
    been playing with the DRZ400 again,
    added a dash to better mount the vapor speedo, a 12v plug with space for som switches.
    also mounted a pair of LED spotlight on her :cheer:
    [attachment=3270]dash.JPG[/attachment]
    dash i added (using plasitc cutting board)
    [attachment=3271]front.JPG[/attachment]
    Showing the mounted spotties
    [attachment=3272]normal.JPG[/attachment]
    normal high beam
    [attachment=3273]spottieson.JPG[/attachment]
    with the spotties turned on
    just thought i’d share :whistle:
    #218344
    Nice Bender, where did you get the two round LEDs come from?
    Sean Ramsay
    Cheers Bender, I see they use deutsch electrical connector which is interesting as we have them at work, would make it easy to wire a set on the Tenere. Easy enough that I just ordered a set. I have been holding out regarding lights as we don’t ride in the dark, but there have now been two instances so I have invested
    Sean Ramsay
    same, normally by time it’s dark i like to be settled, tent up and having a beer or rum in front of a fire, but better to be prepared, spesh as winter coning on and i’ll be riding to work in the dark ( well even darker).
    wasn’t 100% sure as to how to assemble the connecter properly but i think i got it mostly right – lol.
    those lights seem pretty solid mate, i dont think you regret the purchase, – the delivery was pretty quick also
    and they will be going onto a tenere when i can afford one :unsure:
    #218345
    Looking good Bender. Steve
    #218346
    Nice,,,
    I invested in some cheaper led`s to mount as an interim measure for this year. Will save the $$$ to update later.
    Bought Chinese imports for now and will see if they last :whistle: (not expecting too much for the $$$)
    Might come in handy for the upcoming trip to the Birthday bash in June ;) AN early start for me is a certainty and a late finish on the Sunday is probably on the money too :laugh:
    Keep us informed on how they go Bender ;)
    #219162
    Roy
    Is that a solar panel on the front guard?
    #219164
    Sean Ramsay
    Yeah Bundy i strapped it on last trip, knowing that i was riding into the afternoon sun, only put about 30% charge into the phone though, hence the 12v plug that i put into the dash.
    I’m planning to be at the b’day bash so you can check them out there Eagle, and compare . been leaving them switched on when i’m heading into work, making sure that i’m seen – lol, and even took a detour through Lane Cove nat park early one morning and they definately light the road up far better than the normal headlight :cheer:
    cant wait to test in the bush proper
    #218347
    B) My LED`s turned up today from China ,,, El Cheapo set for a test run before the trip to Sunny Corner.
    Had to fabricate some brackets to mount them as the bar mounts supplied were cheap & nasty and I have no real room on the bars anyway :whistle:
    Still need a waterproof switch or bar mount light switch or might even wire them into my Highbeam ??? Undecided on that just yet ,,,,
    They seem to be nice & bright in the shed, so a night run on the weekens might be in order to set the spot angles etc
    Will see about posting up some pics later on :P
    #218348
    pics here
    mounted under the led blinkers
    front view (angles not set yet ,,,
    Bright enough I think :whistle:
    #219832
    Sean Ramsay
    looking good eagle, nice and neat
    you get yours yet TB?
