Bent forks
This topic contains 5 replies, has 0 voices, and was last updated by  Eric Smith 11 years, 6 months ago.
  • #104150
    A mate of mine has a ’98 XR600. 3 years ago he had a crash and ended up in a coma in intensive care for three weeks, with a long road to recovery. Recently, he decided that he was up to the stage that he would like to get back on the bike, so we wheeled the old girl out of the shed and got it going again.
    The handlebars are not straight in relation to the forks. (The crash was caused by wire catching the front forks and stopping the bike suddenly.) We have tried to straighten the bars the usual way, loosening the triple clamps and axle, holding the wheel solid and trying to turn the bars straight, but it is not moving at all. The triple clamps on this bike are unbelievably tight, I have never seen triples this tight. We have tried wedging the triples open slightly and straightening the wheel, with no success, even with two large blokes putting their strength into it.
    We suspect that we may be dealing with one or two bent forks. I think our next step will be to remove the forks from the bike to check. If the forks are bent, can they be straightened (successfully) or are they worth replacing? The forks themselves seem to work ok, sliding freely etc. What would be an approximate cost for fixing bent forks if it is possible?
    Any and all advice appreciated!
    #259318
    Biggeral had to straighten his forks on an xr600 also after a bit of a crash (headon) Perhaps he will chime in soon.
    #259319
    Alan Heather
    Yep had a head on with corey8 when he had a dr 250 bent the frame, forks, and me depends on how bad the forks are bent, I had a dolly made to fit in side the fork tube and gently pressed it out you have to be real carefull, but mine came out spot on had no trouble with leaking fork seals, bigger al.
    #259320
    Not to mention the KDX I brought from a wreckers with bent forks (quite bad) they to were straighten with a press at 33 tonne from memory biggeral? they were left with crease marks and were machined out.
    that bike was raced and owned for a while longer with non issues what so ever.
    #259323
    Nick Dole
    Rule of thumb is a slow bend with no kinks can be straightened. If they are kinked they are junk.
    XR600 forks take a bit of force to bend, not like 400 forks, they bend like cheese sticks
    #259324
    Thanks guys, we will get the forks out and have a look at whether they are bent, and if they are, how badly.
