best Glue for Grips?
Home Forums Tech Help Tech Help best Glue for Grips?
This topic contains 17 replies, has 0 voices, and was last updated by  Bruce Curtis 13 years, 6 months ago.
  • #101790
    Andrew pope
    ok Whats the best Glue for Grips? or other ideas for gripping other than wire as I use wire as well. Just wanted peoples feed back. :ohmy: and is there a specific one that says on the label Grip Glue? :unsure:
    KR
    #228662
    I seen spray paint sprayed into the grip used the other day???? never used it but i supose it would work. I use shoe goo and tie wire
    #228663
    Bike shops sell grip glue not those thieving pricks at westerns but Suttos or the likes. I use it or spray paint grip glue is better and the way to remove it is you warm the grip with a heat gun or hair dryer. Don’t use the glue Suzuki fit their grips on the DRs with but it’s wicked stuff (don’t think you can buy it anyway :laugh: )
    Petrol is popular but I have experienced the rubber swelling. Always wire if you ride in the rain or mud
    I would say don’t glue them, just wire them.
    That’s all I do, never had a problem.
    PTW
    #228670
    I use spray paint. A bit on the bars and a bit in the grip and slide on then tie wire as well. Haven’t had one move yet and I hang on to the bike pretty well. :laugh:
    #228671
    Absolutely Mal! That is the best shit! I usually am flapping of the back like a flag in the wind and that’s all I use. :laugh: :laugh: :laugh:
    Left
    #228665
    I use petrol. Just a teaspoon in and swill it around and tip it out then slide it on. Never had a problem.
    #228666
    Andrew pope
    Thanks guys,
    Will try the spray on stuff and see how that goes…i have always just tie wired them on but i want something a little extra for those extreme moments lol :woohoo:
    #228676
    Hair spray and tie wire
    Go to woolies and get the super heavy duty extra strong type that if used on the old beahive hair dos would act as a hard hat if a steel beam landed on it.
    After all, hair spray is just and adhesive
    Spray on bar, spray inside grip, slips on easy
    #228693
    aroldite
    #228674
    Same here, but I do also use grip wire. It often helps to wrap a layer of insulation tape on the bars before putting the grips on – better for removal.
    #228902
    Steve Wyeth
    Petrol and tie wire. Just cut them off, why would you do anything else?
    #228904
    Boony you are repeat offender in the tech help thread read the rules here
    TheBoss
    #228912
    i used to use the Scott grip glue (rubbery stuff like contact adhesive) but found once it got wet, it let go.
    now i have some Pro taper stuff (much more like supa glue) and it works great.
    we have had our wettest winter in years and they are still on as tight as a nuns nasty ;)
    #228903
    Yep I have found contaminated bar ends to make it hard for the grip to stay put. I have been known to wrap fresh duct tape around the bar and then use the paint/petrol/wire tricks. I’ve seen someone on the trails scrape the glue off duct tape with some petrol and appy that to the bars before sliding the grips back on…. wow.
