bike repare
Home Forums Introduce Yourself bike repare
This topic contains 3 replies, has 0 voices, and was last updated by  Peter Sharman 11 years, 1 month ago.
  • #104333
    Hi fellow dirt riders.
    Have to renew top & bottom head stock race & bearing.
    Does any one have a bearing puller that is long enough to grab the bottom bearing on the head stock.
    If so call me 0418497048
    Thanx Peg
    #260947
    Hey Peg, do you have any access to an oxy set? If so you can apply some heat quickly and it should drop off. You can remove the cage and rollers and apply the heat just to the inner with the stem upside down in a vice, bit of heat and gravity will be your friend ;)
    #260951
    What bike?
    On KTM, Berg and Husky you can press the head stem out of the lower triple clamp and the bearing comes with it.
    #260952
    2012 YZF 450. Aluminum stem. am not keen using heat on aluminum
