This topic contains 16 replies, has 0 voices, and was last updated by stephen nagle 16 years, 6 months ago.
August 28, 2009 at 9:37 am #97080
G,Day OBTers
Just gathered the bits to drop a new piston into the Husky,the last time was rings only and the bore looked sweet.As i’m doing both piston and ring this time it may need honing.
Just wondering if you use the expandable hones or wire ones or its best to take it to a head specialist?
I was thinking the expandable hones may be hard to evenly use without damaging the surface.
Thanks in advance
August 28, 2009 at 10:34 am #150442sounds like a pretty technical job there champ,, you wouldnt want to get this job wrong,,good luck with it..
August 28, 2009 at 10:37 am #150454Nice work Boony in the tech help again :angry:
Twobanger I just spoke with TB he will answer you soon its his trade
August 28, 2009 at 10:43 am #150455Thats better Boony does that mean your sorry, dont answer cya
August 28, 2009 at 10:48 am #150456twobanger, try reading this mate, just be sure your cylinder is able to be honed, some are coated check with your dealer first
http://www.ehow.com/how_4827132_hone-cylinder-wall.html
use one of these hones mate
in trouble Boony? Did I miss something?
August 28, 2009 at 11:07 am #150457Trailboss wrote:
Quote:twobanger, try reading this mate, just be sure your cylinder is able to be honed, some are coated check with your dealer firsthttp://www.ehow.com/how_4827132_hone-cylinder-wall.html
Um?? nope alls good,
do some bores have a special coating that restricts them from being honed??? I never knew that.August 28, 2009 at 11:19 am #150458Yeah Boony for example it could be a Nikasil cylinder lining, they are a coating that shouldn’t be honed, dont worry the Banana can be honed :laugh:
I see you changed what you said earlier
after admin August 28, 2009 at 11:22 am #150460Trailboss wrote:
Quote:Yeah Boony for example it could be a Nikasil cylinder lining, they are a coating that shouldn’t be honed, dont worry the Banana can be honed :laugh:
Honed,,,be buggereed it will be getting bored when it needs work..and yeh once again i didnt read the thread title before commenting but I fixed it real quick ,,well I thought I did.
TBI see you changed what you said earlier
after admin August 28, 2009 at 11:46 am #150443Thanks,
I think its coated, been a while since i had it apart.August 28, 2009 at 12:28 pm #150461Late model husky? like past 12-15 years?
yep ok it has composite bore plating, a mixture of aluminium, silica, chromium and several others in an almalgam, you don’t really want to run a mechanical hone in it. The crosshatching is only put in these bores to bed the rings in ancreate a half decent seal once combustion pressure is behind them. What you do with coated bores is get a good new scrotchbrite and some kero and do it by hand, actually on the 250 I used a round plastic container slightly smaller than the bore and wrapped a scotchbrite around it and worked it one way down the bore and reversred its direction coming back up, continuing until I have a nice light cross-hatching showing, and Bobs yer auntie.Wash it thoroughly in kero and then hot soapy water dry, blow with compressed air and Bobs back in his wifes undies.
August 28, 2009 at 12:44 pm #150462Mr Blue, or twobanger if you want any of the correct industrial engine grade repair style scotchbrite give me an address and I will send you some, I have lots and lots of it left from when I was self employed
August 28, 2009 at 1:32 pm #150463Gees TB how can i say no to an offer like that, I had several grades for furniture finishing, but I’ve used it all up now and my supplier is in grafton where I used to live I’ll send you a postpak if you want?
If I keep getting stuff off you I’ll get a complex….
Thanks Mate.
Bruce
August 28, 2009 at 8:34 pm #150464PM me the address and I will send it. Guess seeing how the master cylinder is a good thing we should work a price out one day :laugh: , dont ask what is worth because I dont know :laugh:
August 29, 2009 at 8:57 am #150444Cheers TB
Ill have a fish around at work for some and if not ill get back to you.ADB ran a story on doing a rebuild on a KTM for stroke and they are using some scotchbright to clean as well.
Mr Blue
Yeah late model husky, but i always call it old cause its getting on a bit.August 29, 2009 at 9:00 am #150445hey mate is it a crome bore or sleeved cast iron?
