Braided Brake Line and Reverse Flush
Home Forums Tech Help Tech Help Braided Brake Line and Reverse Flush
This topic contains 17 replies, has 0 voices, and was last updated by  Anonymous 16 years, 1 month ago.
  • #97928
    Decided to fit a braided front brake line to the KLX250. Got a custom made line from Carters Brake and Clutch at Melbourne St East Maitland. Top quality product and ADR legal.
    Once fitted could not bleed brake from top master cylinder so had to do a reverse flush. This was accomplished by using a syringe and some clear fuel hose. Details here.
    Got a syringe from the chemists (strange looks) and some clear fuel hose. Bit of large hose on bleed nipple and small hose inside larger hose and smaller hose on tit of syringe. All an air tight fit.
    Filled the syringe and hose with fluid and fitted on to bleed nipple. Injected one full syringe. Then pulled the plunger out of the syringe and filled the syringe body with fluid. Repeated operation. Used three full syringe loads of fluid which over flowed the master cylinder.
    Did one bleed from top and all done. Solid as a rock.
    Would highly recommend this modification if your bike does not have braided brake lines. The difference is startling. Now have a solid front brake which was previously as spongy as hell.
    old al. brake_bleed_001.jpg brake_bleed_002.jpg brake_bleed_003.jpg brake_bleed_004.jpg brake_bleed_006.jpg
    #168791
    Nice work Al, Thanks for the tips. ;)
    #168798
    Good work Al – is that your birthday present for your bike?
    Happy Birthday again Old Al
    #168799
    Paul
    Good system Al.
    My local chemist dont carry big syringes but Vets have them for work on large animals and they usually only want their cost price for one :)
    Oh, Happy Birthday Al :)
    klickety click
    #168792
    Nice work there Al ;)
    I have often thought of that hose upgrade for the Super Commuter,,,
    What was the cost of the hose from Carters if you don`t mind me asking?
    I have used them in the past for Brake & Clutches on my vehicles, they are good with service indeed :)
    Cheers Mate
    #168802
    Good topic Al
    Just out of interest. When you refilled the syringe each time how did you stop air bubbles from plunging? I am about to do this job so would it be better to try and source an even bigger syringe?
    old al wrote:
    Isn’t that steel brakeline exposed to the elements? (rocks/logs/branches etc.)
    I wonder Kwaka didn’t run the hose straight too the caliper at manufacture?
    Crash
    ps. good job ol’ Al
    #168800
    WikdBeemer wrote:
    Good system Al.
    klickety click
    Muffberger recons you can get big ones from produce manufactuers. That might be the way to go.
    old al.
    #168803
    Cheers Mate
    $105. Sounds expensive but is a top job and the difference to the brakes is chalk and cheese.
    old al
    #168807
    singletrackmind wrote:
    Good topic Al
    Simply tightened the bleed screw. Withdrew the syringe plunger and filled the body. The hose was still filled with fluid so no air bubbles. Then loosened the bleed screw, depressed the plunger pumping the fluid through the system then when syringe empty tightened the bleed screw. Easy. Did three times then one bleed from the top and finished.
    You are right though, a big syringe would be the way to go.
    old al
    #168817
    Crash
    ps. good job ol’ Al
    The line has a protecive coating over the braided steel. On the later models they do run the line direct to the caliper and that modification can be done to models like mine and Eagles.
    The fork protector also protects the brake line. Hasn’t been fitted in the photo.
    old al
    #168822
    Thanks for the birthday wishes too fellas.
    old al
    #168823
    I have been using syringe for years now, I have a big one that has the end cut so you just push it against the nipple thus not needing the hose. Two full syringes and done very very easy.
    I have rescued / helped a few people with it I will add and they are amazed at how simple it is and how well it works
    STM just get the air out by bleeding out to the atmosphere / ground before you crack the nipple
    Paul
    Good topic Al
    old al
    Also with clear flexible hose you can tilt & tap the bubbles upwards to the plunger and you can see when to stop pumping fluid, so, you could do forward and reverse bleeds with it connected provided you have a big enough syringe.
    Brake fluid absorbs moisture so the less contact it has with atmosphere the better.
    #168828
    Top job there Al
    And happy Birthday for yesterday
    Hope you spent it doing something you love doing mate
