Braided Brake Line and Reverse Flush
Home Forums Tech Help Tech Help Braided Brake Line and Reverse Flush
This topic contains 17 replies, has 0 voices, and was last updated by  Anonymous 16 years, 1 month ago.
  • #168794
    instead of a syringe could you use one of those ‘tom thumb’ 1Lt pumps?
    just take the metal u bend tip out and fit the plastic tube to the bleed nipple.
    just a thought for those that may not be able to get a syringe from a vet.
    the pump can be got at the likes of supercheap.
    it has a 2 way/ dual action? pump= it pumps fluid when you push down on the plunger and as the spring returns the plunger back to the top. if that makes any sense :blush:
    #168848
    one of the problems you will have is most of the pumps arnt clear, so you will have to use some tubing ;) good idea tho Drew
    I have heard of a 1 litre plastic garden sprayer being used. Did the job apparently. Anything will do as long as it can force the fluid through the system.
    old al.
