Brembo brake kits?
Home Forums Tech Help Tech Help Brembo brake kits?
This topic contains 9 replies, has 0 voices, and was last updated by  Dean 16 years, 10 months ago.
  • #96496
    shane
    So, I’m finally at the point where I’ve realised that both front and rear brakes are spongey as feck!
    Changing fluid and bleeding has done no good and I suspect that after seven years and a few good crashes, that the seals are on their way out…
    First question, can someone steer me in the direction of seal kits for master and slave cylinders on the web? (Goggle is not my friend today!)
    Second question, is a seal kit replacement beyond the capacity of Joe Average? I’ve done wheel kits in cars before but never a master.
    If it’s possible, I’ll do it at work (at lunch! of course) and do some pics as well……..
    #137296
    The cylinders may need a clean up hone Shane if you kit them and check for pitting, I dont think it will be the cylinders or brake piston seals to tell the truth, are any leaking?
    You know how to contact me am always happy to make a house call :laugh:
    shane
    Nup no leaks, I have had the cylinders apart for a clean previously and they’re okay.
    I’ll give bleeding another go today before I start hunting down parts and a tutorial on how master cylinders are done:blush:
    When I get stuck I’ll stock the fridge.:S
    #137407
    shane
    Air in the system…:blush:
    I’m a silly billy sometimes!
    #137590
    Thought maybe when you said it had no leaks ;)
    shane
    Air’s getting in there somehow hay?
    Maybe when it’ tax time I might shell out for a seal kit……………
    For now though, it’s time to sit back with a bundy!:cheer:
    #137592
    Has it been upside down recently the bike in question? :laugh:
    #137593
    shane
    Actually now that you mention it…
    I did have a little getoff the last time I went out:blush: unusual for me since I rarely come off and it was upside down AND the brake lever was probably applied when it landed (smashed into the ground):blink:
    #137599
    Hey Shane
    Probably a little late to apply the brakes:woohoo: :silly: :silly:
    Might be talking to ya a little late as you said three hrs ago you going to hit the Bundys:silly: :silly: :woohoo: Maybe we xan talk da same languige as I just finished my even doz of canx of Turkeys. Thats all I’ve got!!!!!B) But I can reminese on your DamnAviator………………………………………………………………………:laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh:
    Cheers, cheers.cheers
    Murph, alias (murph the surf)
    #137633
    :laugh: :laugh: Ha Ha Murph is half cut :laugh: :laugh: :laugh: a dozen turkeys I would be dribbling from every orifice:laugh: :laugh:
