Brembo brake parts,
Home Forums Tech Help Tech Help Brembo brake parts,
This topic contains 7 replies, has 0 voices, and was last updated by  shane 16 years, 8 months ago.
  • #96736
    shane
    I’m after a supplier of Brembo brake parts, particularly a master cylinder seal kit.
    Internets are not being very helpful at the moment (at least as helpful as trying to get that bloody piston back into the m/c, THE most frustrating experience of my year!!) I want to have a squiz and see a)if they’re available and b0 wht price they are o.s., before I pop down and upset the poor parts guy at Suttos when he asks, “What sort of bike is it off?”
    Erm…
    Can someone please point me in the right direction re. weblinks?
    Also the piston does not want to go back in. Has anyone rebuilt one of these puppies? What’s the trick? (By the time I’m finished with this one I’ll need new seals, having had a tantrum and thrown the old ones out onto the street!)
    #142007
    Shane I have a master cylinder of a CRF450 that could be fitted and work fine, is new and would do you a price and fit and bleed it for you I reckon
    shane
    Sounds like a plan old man!
    What brand is the honda one? How does the light switch fit up?
    I’m really keen to rebuild the original one since the bore looks good still, just need to hunt down parts. Time’s not an issue at the moment because I’ve decided to check the valve clearances, poor old bugger doesn’t want to start on the electric leg which tells me they may need doing, it never ends…
    #142039
    Whats the oil leak mate?
    shane
    Haven’t got to that yet. It looked like it’s at the oil filter cover, probably the flimsy ‘o’ ring again. Or the mechanic didn’t tighten it properly!:laugh:
    Either way I’ll have to degrease it and have a peek…
    #142043
    Shane if you don’t want the CRF450 M/C, TB would you mind PMing me with a price, cause that is part of the fix for my spongy rubbish front end stoppers. the whole setup is the total go, but the M/C off the honda is a known fix.
    Shane can’t help you with a cheap supplier, but Ducati’s and KTMs’ both use brembos, and there’s a seller on ebay I’ve used to get bits for them before.
    Bruce C.
    #142062
    shane
    I have three words to beware!
    silicon
    based and
    fluid!:(
    Guess whch dumbarse didn’t properly read the container and now has a handful of swollen seals!!!!!!
    I dunno if I need a m/c yet still hunting for parts…but I’m in no hurry either
    #142041
    shane
    Yep as I thought, o-ring behind the filter cover. leaked like a bitch this time though :blush:
