Broken frame
Home Forums Tech Help Tech Help Broken frame
This topic contains 16 replies, has 0 voices, and was last updated by  Roy Stanger 14 years, 7 months ago.
  • #100282
    Roy Stanger
    Hi
    my XR250R has broken the frame just behind the right hand footpeg. There is a dodgy weld there from a previous owner and it has cracked all the way around the tubing. I can open the gap up just by pushing down on the footpeg
    Obviously I’m going to pull the bike apart and fix this, just wondering if anyone here had any helpful comments, tips or advice
    cheers
    Roy
    #206111
    Roy, I think Bollocks had his old XR break in the same place. I know it got fixed but for the life of me I cant remember what they did. Hopefully Bol might stick his head in here.
    #206117
    Krustys was fixed at a welder in Penrith. Roy I think any good engineering shop / good welder will do a good job
    Roy Stanger
    I bought this bike from a bloke in Tamwoth, what are the odds its the same one ????
    #206120
    :D :D :D
    Without knowing exactly where the break is, you may be able to shove a bit of roundbar inside the tube and leave a gap when you reweld it so that you weld to the round bar as well for added strength.
    #206121
    Odds are pretty good I`d say :laugh:
    Jeffro is on the money, he knows his welding (that`s his career) ;)
    Good Luck with the repair Roy
    #206112
    How old is the XR?
    #206113
    Roy Stanger
    2000 yr model
    #206125
    It will need plating somehow as a welded crack just cracks again. Without pics its hard to know.
    #206122
    Gday, Roy.. Go and park the 400 at the top of a hill on its stand,,, walk away and if it falls over ,, bingo its Bolls old one… :whistle: :whistle:
    #206131
    Roy Stanger
    ok, not same bike, mine a 250
    #206126
    Roy Stanger
    yeah my farmer brain is telling me to plate it , but a bike frame is a bit different to planters or chisel ploughs that I do most welding on, so wasnt sure
    #206114
    Roy I used these guys in Penrith for my old XR400… http://www.sandrpro.com/aboutus.htm They do great work and quick turn around… They specialise in all things Motorcycles..
    Cheers…
    #206133
    I am a farmer as well. Know what you mean.
    #206139
    do yah recon you should dove tail the plating to add more bite to the weld??
