Bulging Tube
Home Forums Tech Help Tech Help Bulging Tube
This topic contains 14 replies, has 0 voices, and was last updated by  Dean 12 years, 5 months ago.
  • #103357
    Ryan
    G’day all,
    I got a flat and finally got around to changing it tonight. In the process I pinched it twice, I need the bike tomorrow, do you reckon a bicycle repair kit will do the job? Also if has anyone ever encountered a bulging tube??? I blew one up and its bulging in one section whilst the rest of it remains uniform.
    Any advice would be gold.
    Ryno
    #250820
    Let some air out and the bulge will go away.
    Your welcome
    ian
    thought i could help you out but a little bit to far from me
    #250825
    You should travel for him
    #250826
    Ryan
    In Sth West Sydney, do you think the bicycle repair kit patches will do the job?
    #250827
    Bike repair kit will work ;) Might pay to rip into a supercheap and get some tyre slyme as insurance.
    Ryan
    No worries, any tips on how not to pinch the tube, I only have flat head screwdrivers to replace the tyre with….
    #250822
    Brett
    If its a UHD tube the patches don’t seem to take that well.
    I tried it on a ride to orange with TB when it wet flat the second time he killed for ever.
    Put a 21 front in and it lasted till I got home 300+ kms
    Not really the worth the effort if you have a front just stick that in.
    That was assuming your dealing with a rear
    #250829
    Ryan
    I only have the one tube. I will see how I go if I can get it to hold pressure tonight I will replace it if not I’ll buy a new tube in the morning.
    Cheers for your help everyone.
    #250823
    Ian Kersley
    Patches, ok to get home, never leave home with them.
    just my opinion
    bones
    #250832
    If you are anywhere near Penrith tomorrow I have plenty of tubes and will change it for you
    I agree with Chicken for some reason they dont like the UHD tubes
    Why would you use screw drivers for changing a tyre ? :ohmy: do yourself a favour and get a couple of sets of these http://www.torpedo7.com.au/products/T7TO4N0TL/title/torpedo7-260mm-tyre-lever-set—2pc
    they are good quality and make sure your technique is correct, ie make sure the bead is is down in the well, if you are struggling,your doing something wrong.
    Patches wont stick I am told to UHD tubes because of the high real rubber content in the tube. Also remember that UHDs lose pressure over time because the rubber leaches the air slowly ;)
    Leo.C
    just for into too a mate of mine works at a tyre joint and says all tubes from standard to UHD and moto to tractor type bulge on one side. But when they’re in the carcass of the tyre they’re not going to do it ay ;)
    BW
    #250834
    WHen you get that new tube grab some tyre levers as well, that will reduce the risk of piinches. Also take care to only put the minimum amount of the lever you can to minimise the pinch risk. Try to just use the bent tip at the end of the lever.
