Buttaba-Gap not quite to Bangalow
Home Forums Ride Reports Buttaba-Gap not quite to Bangalow
This topic contains 16 replies, has 0 voices, and was last updated by  scott bocking 15 years, 2 months ago.
  • #99376
    Woke early (of coarse) to a grey and cool morining
    Rain gauge showed 6mm
    Austblue was first to turn up and we put a bit of air in his tyres
    Rode down to the meeting place to greet the others
    Jeffro had a bit of an issue with the electrics on the Berg but managed to get it going (no electric start for him for the day)
    Waited, waited, waited and then waited some more for Diddel and Dan
    They eventually showed over half an hour late then they had to go get fuel
    Waited, waited, waited again, evidently they found the servo easy but got lost coming back
    Shame on you Diddel for taking the long way (or should I say wrong way) to get to the meeting place
    Riding by 9:00, straight into a very tight single up to cross Wangi Rd and down into Tims single
    Tim, Diddel, Austblue and I popped up the first of many tests while the others opted for the easier option
    Pics to come
    #193815
    Meet and greet
    Tim
    Diddel
    AB
    Might have to continue this story with a bottle of Turkey
    Only half the pack made it to end of Tims single so I backtracked and found our illustrious sweep, Dude helping Jeffro with a flat rear tyre Gave Jeffro my spare tube and a couple of gas cannisters and before long we were into again. After regrouping we did some open stuff to cool down
    Dude and Jeffro hard at work
    Inovative bike stand
    Crossed the haul road and through the rail tunnel into a succession of great singles
    Passed the Moto track and headed for K9 loop. Almost everybody made it up K9 (bad luck AB). Smart arse Tim took on the hard way and had the little 200 jumping from rock to rock
    Diddel
    Justo
    Pete
    AB, with Tim heading for the steps
    AB’s better attempt
    #193829
    Linked all the singles from there to the Gap which consisted of many test pieces including one very snotty uphill that only Tim and I did and a huge very steep downhill
    Tim on the very snotty uphill
    Tim stepping out
    Tim offline but making it :woohoo:
    Another bloody hill
    AB’s second attempt
    Pete
    Jeffro
    Diddels second attempt
    Arrived at the Gap for a well earned burger and cold drink. Topped up fuel tanks and had a rest.
    It was here we bid our farewells to Justo, Jeffro and Dan (well done Dan, including Diddel losing his way to the ride start you had a pretty big day out) The rest you fellas, well maybe next time.
    Met Young Justin at the Gap and he wanted directions on how to get to the Wato’s, so I said he could follow us. ;) ;) :silly: :ohmy: :S
    #193833
    Heading south along the base of the range we travelled through a lot of overgrown lantana which slowed the pace at times Did the diversion track and then on to Tims and my single which had a fresh tree down but managed to get round OK.
    Then it was on Man against mountain
    Most made the first stage except me Hit it with a little more conviction next attempt and nailed it.
    Stage 2 saw some carnage with Young Justin coming to greif and rolling down the side of the mountain for a bit. AB had quite a few misshaps so we put a sling on the bike and helped him up.
    Stage 3 “The Crux” was done first by Diddel then me. (Thanks for the help on that silly little step at the top Diddel) Next was Young Justin who managed it with some help from the crew.
    Tim had a go at the harder way but it was just a little bit too wet and he ended back on the normal line. At one stage he had made it almost to the top of a step but began spinning to much so I grabbed his handle bars trying to help. Unfortunately I grabbed his kill switch and the bike cut out making him slide back down to the base of the step. He wasn’t impressed at the time but I think he see’s the funny side of it now
    AB’s attempt was hard work for everybody but he did get to the top of stage 3
    A very big thanks to the Dude and Pete who had walked up to help out and watch the carnage, they took the easy route to a meeting spot which took us another hour to reach
    Young Justin??
    Young Justin in the grandstand
    Tim failing the harder way, better than I could do though :ohmy:
    AB doing it tough
    Diddel about to bring the front wheel back to earth :ohmy:
    Slings came out again ;) :P :P
    Diddel and me dragging AB up
    Tim still on the high side ;)
    Nice way to turn around, Tim. Ha Ha :P :P
    #193835
    Most thought that the hill was over but little did they know there was stage 4,5 and 6 to go. Hee Hee Hee.
    Stage 4 was mostly done without incident, well sort of??? Managed to get past the big log and on to stage 5. This proved to be a challenge as the slab was a little too wet
    Diddel went first but failed and on his second attempt he tried the gutter to the right but it was also a no go.
    I gave it my best shot but I too was spat off the slab and into the gutter Pulled my bike out of the gutter and tried to start on the rock slab. No matter how subtle I was with the clutch the tyre just would not bite so it was back to the bottom for another crack. My second attempt was better but not pretty. Diddel got it next go and then we watched AB have a go but he also failed and the slings came out again but man it was hard dragging a bike up a slab you could barely stand on. Tim and Justin nailed it considering the conditions
    Tim and Young Justin at the escarpment
    In the jungle
    The slab :unsure: :ohmy:
    From there we hit a few more very slippery rock slabs before getting to stage 6 “the dreaded tree root steps”.
    With a little help from each other we eventually made to the top
    #193837
    Geez AB has given his pipe some loving!!
    #193838
    Rode the main track back down to meet Dude and Pete who were waiting very patiently :blush:
    Young Justin discovered a leak from his RH radiator and thanks to Diddel (who had a tube of quick metal in his pack) we had the bike lying down and plugging the split with the epoxy.
    Good job done and it was back down to and an up paced ride back to Becks Road :woohoo: Across Freemans Drive, through the quarry, under the freeway and to an intersection where we said goodbye to Diddel and Young Justin. Thanks dudes for coming along. Diddel, next time bring our guests the easy way mate ;) :laugh: :laugh:
    From there we travelled back under the rail line and took a different route home ending with a very steep descent into another one of Tim’s and my little singles. Sweet.
    Arrived home about 5:30
    Big thanks to everyone for turning up and making it a great day out :woohoo: :woohoo:
    Bigger thanks to Dude who swept nearly all day. Your a legend mate :)
    Will do it all again for those who dropped out at lunch time and anyone else who is up for an extra ordinary day out. Its amazing how far you can push these machines before you actually have to get off and push these machines :laugh: :laugh:
    Murph (easing the pain with Turkey as medication) the surf
    #193839
    Your right Mick, hope that it was like that before our ride :laugh: :ohmy:
    #193816
    Great report murph… I cant add much to it apart from I had a pearler of a time. Enjoyed the many testing sections that were thrown in with out any warning… Just dissapointed that time beat me for the first time ever on a ride and had to bail out after lunch :angry: … thanks to you for leading the ride and dude for sweeping, Also thanks to all who went on the ride for an enjoyable day out…!
    Will be there for the next one for sure… :laugh: :laugh: :laugh: ;)
    Cheers justo
    #193857
    I’m not sure Justo?
    But I was cramping pretty bad towards the top of the said mountain :(
    Should we cut :ohmy: some of the singles out of the first part of the ride to give more of a chance of getting more people up said mountain.
    Then again said mountain is only for the insane or those who should be omitted
    Be Warned
    Paps I could put down a grade of 6 but its not within my nature
    I call most 6ft surf sessions 4 to 5ft
    I don’t like to big note myself
    So I usually under call it
    Back on track-Does anyone know of one thing to get rid of this monkey butt?? Unfortunately I’m getting a little long in the tooth for standing on the pegs all day, maybe I’m just getting lazzy ;)
    Next question
    Is there a drug/remedy for cramping??
    Even my young fella, Tim suffered from extreme cramps yesterday
    Understandably it was an extreme day out but surely my kid could of done it without cramping
    Like to hear any response
    Almost Turkeyed out Murph
    #193859
    Great report Murph and others. I’m getting worried about riding with you guys now. :laugh:
    Monkey butt: there is a powder you can get I think from Ballards or any bike shop probably. I have found that a pair of ‘Skins’ type pants under the riding pants helps heaps. You can get the cheap brand from Big W or Kmart for about $40.
    Cramps: Try magnesium powder. I use ‘herbs of gold’ brand(from health food shops)and find it works if used as directed. I have also used the stock standard endura and find it helps with hydration and cramping.
    Hope that helps you old man. :laugh:
    #193863
    AAAha
    Old man is it??
    I love showing you young kids the right path to take through life :woohoo: :kiss:
    Glad you only listened to half of what I”m talking about!!
    Surely, in our age of quick fixes and drugs there is something to help with severe cramp :unsure:
    Some one did say once there was something available from a chemist??
    I don’t do drugs anymore but if there is something out there that stops me from stopping the thing that stops me doing the things that I love. OOPS OOPSY
    Lost again
    This real world is starting to hurt :dry:
    Still keen on a remedy for cramping B)
    #193865
    Dudes View B)
    Unreal weather. :laugh:
    No dust. :laugh:
    The pace was on all day. :cheer:
    Some mechanical dramas now and then but all went well. ;)
    A big days ride. ;)
    Fun. :cheer: :laugh:
    A great way to start 2011.
    some vids and picks.
    http://www.youtube.com/watch?v=8rdnpvMxz1M
    http://www.youtube.com/watch?v=c9mxV21GSBo
    http://www.youtube.com/watch?v=iQIRj6hB9PY
    http://www.youtube.com/watch?v=KAgAg2FIIOs
    imagine you were here
    #193931
    Great videos Dude thanks for making the effort to loaded them mate. Great read Murph always entertaining I will be up for one of these soon on a test bike ;)
