Cam Chain Removal XR400
Home Forums Tech Help Tech Help Cam Chain Removal XR400
This topic contains 4 replies, has 0 voices, and was last updated by  Shayne O’Neil 14 years, 7 months ago.
  • #100318
    Hi all, been awhile since I posted but finally getting active again. quick question for the XR experts in here.
    Just wondering if anyone can give me a heads up on replacing the cam chain without having to remove the side covers. The cylinder etc is at the shop getting rebored so I thought I’d get into trying to change the cam chain.
    Have looked and searched but cannot find anything particular and the manual doesn’t even mention cam chain replacement.
    Bike is a 2000 XR 400 currently in the process of upgrading the suspension and giving it a good freshen up both bodywork and engine wise.
    Planned work is:
    Mikuni Pumper Carb
    Gold Valve suspension with new springs
    RSW Top Triple Clamp
    New Vapour speedo
    XR’s only Exhaust
    Powerbomb Header
    426 kit
    Top end recondition
    Stage 2 Cam
    New plastics
    New seat cover
    Heavy Duty Clutch Kit and springs
    Powdercoated frame
    Clarke 16lt Tank (old one cracked at join marks)
    renthal Bars
    Barkbusters
    Hyde bashplate
    Alloy Rear disc guard
    New bearings all round
    plus more to follow when cashflow catches up.
    Will post pics of the reconditioned beast in the near future.
    Bulla
    #206716
    Found the answer – unfortunately looks like I will have to remove the rh side cover and clutch basket. Need to put the new clutch in anyway and will give me a chance to check around the bottom end as well.
    #206752
    Yeah sorry just seen this thread as I have been out. Yeah right side cover clutch, clutch basket and case out like you said. Easy from there mate.
    Cheers TB
    Will post on here if I have any issues
    Thanks
    #206778
    Cam chain all changed, just broke the bloody clutch centre when I was tightening it back up – should have used the special tool instead of the stand in screwdrivers – managed to pick up a used one for $65 – Lesson learnt, get the shop to tension it up with the special tool for $5:(
