carby set.. 4 klx450r with bombheadder?
Home Forums Kawasaki Bikes Kawasaki Bikes carby set.. 4 klx450r with bombheadder?
This topic contains 11 replies, has 0 voices, and was last updated by  Dean 17 years, 1 month ago.
  • #95750
    aaron childs
    Hi guys
    fitted my bomb headder and what a differance,though wondering if i should play with my carbie. any suggestions in mixture settings etc…..:unsure:
    #119333
    aarochild wrote:
    Hi guys
    just ride the thing man:woohoo: if it crackles on decel it may be a bit lean and when you hold it wide open if it feels flat also lean, just a bit of fine tuning is all thats needed. PS aaron I was checking out your arse:blush: whoops I meant style:laugh: on Saturday,you are a loose unit and I could tell you where having fun;) awsome stuff mate.
    #119334
    aaron childs
    thanks for the help ollie ,
    not too mech. minded (though only need to be told once)can fiddle though wouldnt do a rebuild yet without a HANES manual lol.
    Yea had a ball on sat. LOOSE NUT? im sure i saw you skipping down a hill past me on more than one occasion! lol:laugh: :laugh:
    play with both? it crackles (slight) on decel. .,More fuel needed??:blush:
    #119349
    Yeh mate,just adjust your fuel screw out 1/4 a turn at a time have a ride between adjustments. Remember where you originally started from (write it down) so that if you f**k it up you can always go backB) Jetting will also change with Temp,humidity and altitude.
    make sure bike has warmed up first.
    I think there is a jetting guide on this forum somewhere which would help ya out.
    http://www.mxnewsfeed.com/phpbb2/viewtopic.php?t=21
    #119350
    This is also a awsome description of how to jet your Carby.Its the one I always refer to anyway.
    hope it helps
    Mods: Sticky?
    http://www.duncanracing.com/techfaq/Tech_keihin-carburetion-jetting.phtml
    #119336
    aaron childs
    Thanks heaps ollie the info is very helpful, Though seems i have to install a fuel screw!?. Can i just fiddle with air intake in the meantime??:unsure: :blush:
    #119337
    aaron childs
    The fourstrokes have a fuel screw the 2 bangers use an airscrew basicly do the same thing but different if you know what I mean:unsure: You can still adjust your standard carby its just a bit fiddlier than it should be. unless you have a special tool,you have to rotate your carby to get access to the flat blade screw,You can get a fuel screw from ballards for about $30 fairly cheap they make life easier.
    cheers Ollie
    #119335
    aaron childs
    cheers ollie ya legend that probly cost me double if sent to my shop…..you fellas need to make a guide for 4stroke dummied;)new-1.jpg
    #119548
    AAron check this link out – its got pictures!!:laugh:
    the black screw with the knurled top is the fuel screw Im talking about,it replaces the standard item that sits in the front of the carby underneath.
    http://www.dirtrider.com/tech/141_0707_keihin_fcr_carb_rebuild/photo_04.html
    #119338
    aaron childs
    Cheers ollie
    shaaaaaaame:blush: :laugh:
    #119339
    Craig Hatton
    Hey aarochild
    This link has heaps info for klx450, hope you can find something
    cheers hatto
    http://www.thumpertalk.com/forum/forumdisplay.php?f=379
