casedguards on drz are they neccessary?
Home Forums Mud n Tar Suzuki Bikes Forum Mud n Tar Suzuki Bikes Forum casedguards on drz are they neccessary?
This topic contains 23 replies, has 0 voices, and was last updated by  Chris 15 years, 1 month ago.
Viewing 9 posts - 16 through 24 (of 24 total)
  • #193894
    as a guide Husky i just bought a 8×4 foot 2mm thick sheet of aluminium for $120.
    so if you go to a metal work shop that uses alum. with the diameter of the disc(s) you want they’d probably only charge a couple of $$ for the alum. and a few $$ for labour.
    i’d offer to cut some for any that would want some but ATM i only have a jig saw and the finished product is not that flash :blush:
    however if someone does want some cut i can get a price from a local shop to plasma cut some.. i’d prob. recommend 3-4mm over 2mm though just to be on the safe side, i feel the 2mm stuff may tend to bend too easily.
    but if someone can have a look at the ones they have and let me know thickness and are both sides the same diameter??
    #193900
    I have seen two DR gear sticks crack the left case and one brake pedal the right side. They are a super necessary piece of DR kit I reckon and as stated the tour companies fit them and as they do they must be needed. Having seen those poor Cape York hire DR’s I can tell you they get nothing until its rooted :laugh:
    XY I could be wrong as I normally am :laugh: but I reckon the ones people purchase would only be two mill thick mate
    Nick Again
    Cape York tours use 3 mm. and Sikaflex to hold them on.
    #193903
    See :laugh: :laugh: :laugh:
    #193575
    Nick Again
    I have done some more reading on this and found that apparently the DRZ400’s gear shift has a bit of a hook on the inside of it, filing this off seems to do wonders in helping to preserve th ecase on that side.. Brake lever side.. No Idea :laugh:
    #193979
    Case savers are on now,,,,tick that box.
    #195552
    Bloody lost one of mine at Hampton, next time I will sicaflex them on.
    #195555
    or that should be sikaflex my bad.
    #193728
    Nickj wrote:
    Silicone adhesive was recommended when I did mine so if for any reason they need to be removed an old butter knife would easily cut the silicone off. I have done over 8000km with mine on and they haven’t budged!
    +1 I have 12500ks and they have’nt moved and have taken some love over the years!! Good cheap insurance IMO. :)
