Home › Forums › General Bike Talk › Castor Oil ???
This topic contains 33 replies, has 0 voices, and was last updated by drew 16 years, 7 months ago.
July 16, 2009 at 11:30 am #144080
If you want the smell of R30, with the benefits of todays technology, Silkolene top o’ the line 2T oil is the best stuff out there, I only changed after getting hold of some Mobil, doesn’t smell as good, but lubricates as well and burns cleaner.
July 16, 2009 at 11:49 am #144053in a 4T if just for aroma therapy i’d try some of the R/C nitro premix stuff, and i’m being that it has a hypnotic smell to it i’m assuming/guessing it’s castor based too.
might try some in the old man’s yami ag and see what results:silly:
from what i can read up on castor in R/C stuff the castor gums up less?
just read this
http://www.perthstreetbikes.com/forum/f64/two-stroke-oil-discussion-64912/
interesting stuff indeed.
July 17, 2009 at 5:07 am #144094Just noticed 1500 post have slipped quietly by for Champo without all the fanfare of others. Well done Champo, no doubt informative and insiteful every one of them
July 17, 2009 at 11:02 am #144090Mr Blue wrote:
Quote:If you want the smell of R30, with the benefits of todays technology, Silkolene top o’ the line 2T oil is the best stuff out there, I only changed after getting hold of some Mobil, doesn’t smell as good, but lubricates as well and burns cleaner.BC
You talking about the Pro 2 or the Comp2 Plus, Bruce?
July 17, 2009 at 8:33 pm #144152
AnonymousJeffro wrote:
Quote:Just noticed 1500 post have slipped quietly by for Champo without all the fanfare of others. Well done Champo, no doubt informative and insiteful every one of them
i think that boony character has just made a big fat hairy deal about it, in it’s own thread:blush:
August 7, 2009 at 8:46 am #144226Just a bit of avation history on Caster Oil for any one who’s interested.In World War 1 the british developed a raidial aircraft engin call’d a “Nome”, put it in a now famous plain call the “Sopwith Camel”It did well shootin down the Jerry’s.Anyway the cylinders of the engin spun around the crank & pistons insted of the other way round,a cooling inovation, you could’nt have oil in the crank case so they had a sistem where the oil was injected into the crank then blown back out unburnt,so it was caster oil they used.Thats one reason why the airmen used to ware long scavs round there necks so they could wipe the oil of there gogles with it.So Caster Oil has bin in engins for a wile now.
August 7, 2009 at 8:51 am #147365The 2nd development of the sopworth Camel was the Camel toe I am informed :laugh:
August 7, 2009 at 9:06 am #144054It goes good on ya new boots too Eagle:P
August 7, 2009 at 9:53 am #147367Trailboss wrote:
Quote:The 2nd development of the sopworth Camel was the Camel toe I am informed :laugh:TB
and it was a v-twin:laugh: :laugh:
August 7, 2009 at 11:28 am #144209axel wrote:
Quote:Mr Blue wrote:Quote:If you want the smell of R30, with the benefits of todays technology, Silkolene top o’ the line 2T oil is the best stuff out there, I only changed after getting hold of some Mobil, doesn’t smell as good, but lubricates as well and burns cleaner.BC
I’ve used both Axel and they are both based on castor i believe…excellent oils.
Bruce Cee
August 7, 2009 at 11:31 am #147418Mr Blue wrote:
Quote:axel wrote:Quote:Mr Blue wrote:Quote:If you want the smell of R30, with the benefits of todays technology, Silkolene top o’ the line 2T oil is the best stuff out there, I only changed after getting hold of some Mobil, doesn’t smell as good, but lubricates as well and burns cleaner.BC
Bruce Cee
mr Cee, i have some of the SIKolene castor for the weekends riding. im gonna stack trying to smell my own exhaust….i have premeditated it:laugh: :laugh:
(shut up boon)
August 7, 2009 at 11:57 am #147419menace wrote:
Quote:Mr Blue wrote:Quote:axel wrote:Quote:Mr Blue wrote:Quote:If you want the smell of R30, with the benefits of todays technology, Silkolene top o’ the line 2T oil is the best stuff out there, I only changed after getting hold of some Mobil, doesn’t smell as good, but lubricates as well and burns cleaner.BC
Bruce Cee
(shut up boon)
I now need counciling,, I`m having visions of spidy flat out on the KATO (15kph) , no pants and turning around trying to sniff his own exhaust pipe,:woohoo:
August 7, 2009 at 12:04 pm #147423Boony wrote:
Quote:menace wrote:Quote:Mr Blue wrote:Quote:axel wrote:Quote:Mr Blue wrote:Quote:If you want the smell of R30, with the benefits of todays technology, Silkolene top o’ the line 2T oil is the best stuff out there, I only changed after getting hold of some Mobil, doesn’t smell as good, but lubricates as well and burns cleaner.BC
Bruce Cee
(shut up boon)
I know need counciling,, I`m having visions of spidy flat out on the KATO (15kph) , no pants and turning around trying to sniff his own exhaust pipe,:woohoo:
Awwwwwwllll…..
one of these days boony, POW, right in the jackie gleesons
August 7, 2009 at 12:29 pm #147425You Blokes do know back in your Mums’ day castor oil was given by the teaspoon full to “loosen” things up in the exhaust area don’t you?
use too much Menace and you might loose traction in the “mud”, wear some rubber undies my friend, ask Boony he would have several pairs I’d say, hanging up with his catwoman suit and whips.
BTW the last bike i pulled down that had been running Silkolene Comp had a beaut film of oil all over the bottom end, something everyone likes to see when checking out the bottom end of their smoker.
August 7, 2009 at 12:47 pm #147428Mr Blue wrote:
Quote:You Blokes do know back in your Mums’ day castor oil was given by the teaspoon full to “loosen” things up in the exhaust area don’t you?use too much Menace and you might loose traction in the “mud”, wear some rubber undies my friend, ask Boony he would have several pairs I’d say, hanging up with his catwoman suit and whips.
maybe i was overdosed as a baby on castor…and thats why i think 2 strokes are fooly….rad and sick:laugh: :laugh:
is that how it goes young bull blue:P
