Chain Slideer
This topic contains 5 replies, has 0 voices, and was last updated by  Mal 14 years, 7 months ago.
  • #100267
    Is it possible to replace the chain slider on a 2002 xr250 without removing the swingarm?
    If so, what is the procedure?
    #205835
    Not sure about the XR but with my bike I used to take the front sprocket off and you could get the slider in from there.
    Most sliders should be a U shape and not need the swingarm off to install them.
    Hope this helps.
    #205838
    From memory many years ago you have to pull the swingarm off, if its a genuine one.
    Yeah, thats what the service manual says. I’ll try it Mals way first – see how it goes.
    Thanks fellas.
    #205836
    Yep, you can get a slider in and out with a bit of manipulation.
    Need sprocket cover off, no need to remove sprocket (mines only 12t).
    #205932
    Excellent! :woohoo:
    That’s better than dimantling half the bike.
