Changing your own tyres – worth it or not?
Home Forums General Bike Talk Changing your own tyres – worth it or not?
This topic contains 14 replies, has 0 voices, and was last updated by  Alex 13 years, 4 months ago.
  • #102086
    Andrew
    I have just changed both front and rear tyres on the bike by myself for the first time. It took me just under 2 and a half hours using 2 short levers…what a %$&* of a job! :angry: The front went on okay but the rear was a dead set bastard!
    While there was a bit of satisfaction in doing it myself and i saved around $50 from the bike shop,i have scratched the rims something shocking :pinch: and with the time it took i am really wondering if it was worth the effort? :S
    I used WD-40 to help get the tyres on and off and next time will have more than 2 levers.
    Apart from that, has anyone got any advice or techniques they use to help simplify this job or do you reckon it is better to just take them to the bikeshop in future?
    #232606
    Practice makes it easier. If you get stuck on the side of the trail somewhere it does help to know how to do it your self.
    Some tyres are tougher than others to change.
    What bike did the wheels come off?
    #232607
    :laugh: :laugh:
    I do all mine myself ACE,,,Takes me about 45 mins to do both usually, no hurry . Also good practice for if & when you get a flat on the trail and have to do it on the dirt with less gear. :S
    Have learnt a few tricks along the way :whistle:
    1.Warm the new tyres in the sun if possible
    2.Run the old ones with valve stem removed or real low pressure if possible to warm them up & help loosen the bead. Depends on the type & brand of tyre, some are bastards to get off, others not so bad :)
    I imagine the ones on the rear of the 800 are pretty firm in the sidewalls :S
    3.I use an old rear tyre on the floor as a stand, some guys have a couple of old tyres strapped together to get more height, or make a home made stand from an old car rim. Really saves the rim and brake disc from damage too,,, Or buy a change stand from Suttos ;)
    4.Grab some more levers,,,, I have 6, longer ones are better to have at home.
    5.Use rim protectors (plastic doovers that sit between rim & lever) I use bits of rubber cut to fit
    6. I use a spray bottle of soapy water or rub liquid soap around the bead with my fingers to help the new tyre slip on
    7. Use talcum powder insde the tyre and on the new tube to enable movement there as well
    Any more tips needed ????? :whistle:
    Best tip of all,,,,,,,,
    GET TB TO FIT THEM :silly:
    He loves doing it :silly:
    #232613
    TB gave me the best tip of all ..
    Take the tyre off both sides of the rim then push the rim down into the tyre and pull out.
    Put a part inflated tube into the new tyre and fit the valve into the rim then lever on , it can only be done one way.
    It takes me about 15-20 minutes to remove wheel , change tyre and refit and that includes a stubbie break :D
    Jimmy is spot on it gets way easier the more you do.
    Andrew
    Hi Jimmy, they came off an F800GS. I suppose a good amount of time was spent trying to protect the rims…fat lot of good that did! In the end i didn’t care too much about that. :whistle:
    Will probably do them all myself now…just looking for some pointers. Thanks.
    #232614
    Andrew
    :laugh: :laugh:
    I reckon the quickest way for me to change my tyres is to take them to your place. Seeing as though you are so good at it, you can change mine while i drink beer and watch! :laugh: :P ;)
    #232621
    All good tips above!
    I was shown that tyre over the rim thing at a Denman pony express. I have never been able to remember how to do it. Got any photos of doing it????
    Motoz tyres were the worst I have tried to fit, and it was for a mate…..
    The best tip might be to pretend you can’t do it and watch someone else struggle with them….
    #232620
    Maybe one of these in the shed to help out Ace,
    The tire over the rim is the easy and best way.
    The tires on the Tenere need changing, you should come over Ace and try it out on them. :laugh:
    If you can change a tire on a GS800 you can change them on a Kenworth 904 ( same rim i think ) :P
    PTW
    #232608
    :laugh: :laugh: :laugh: :laugh:
    A lot of help you blokes are :woohoo:
    Watch these old vids we did in 2009 mate,,, note the home made stand I mentioned
    http://www.obtrailriders.com/index.php/forum?view=topic&catid=8&id=42448
    #232622
    Heres a thread from the DIY section of old bills that explains all ;)
    tyre changing thread
    #232609
    I forgot to mention that rear tyre was a Mitas STONEKING and yes, they are hard as STONE in the sidewalls :whistle:
    And it was stone cold, hence hard to start the removal process :laugh:
    I keep forgetting to make a stand like that,, need to find a couple of old rims,, just don`t have the rod so long in the middle !!!!! Could be dangerous in an accident (slip over & land on it & you could be in strife) :unsure:
    #232610
    Have a bit of look around ace ,pick a target, batter your eyelids and promise heaps of beers and friendship for life
    If that fails mate…big cable ties and head towards the nearest dealer..even if its 100 km away and your down to the rims :laugh:
    If that fails…burn your bike to keep warm,then walk home in the morning :silly:
    3 cheers for bike shops !!! :cheer:
    bol :woohoo:
    #232623
    Andrew
    PTW
    :laugh: :silly: :laugh:
    :P
    #232624
    Andrew
    bol :woohoo:
    Hip hip hooray…hip hip hooray…hip hip hooray :laugh:
    and i will keep a BIC on me as a contingency ;)
    #232625
    I have an old KINGS Chinese tyre here that will make you all rethink changing tyres without car levers, 6 beers and 000 on speed dial.
    Seriously, soap or soapy water with a warm/hot tyre is a great advantage.
