CHEAP TYRE CHANGERS
Home Forums Current Sponsor Deals Current Sponsor Deals CHEAP TYRE CHANGERS
This topic contains 34 replies, has 0 voices, and was last updated by  Greg 15 years, 9 months ago.
Viewing 5 posts - 31 through 35 (of 35 total)
  • #178841
    Will do Mick, when assembling the unit like Mickp said leave all the bolts loose until they are all started then happy days
    You can assemble it for me,even if I get it right you’ll say I did it wrong. :laugh:
    True Mick so true after you have had a beer you are as handy as a hit in the balls
    http://www.youtube.com/watch?v=xT7emRNEnTc
    But back on topic yes mate they are a deal and I would love the help and put yours together :laugh:
    See here for the bargin of 2010
    Trent
    In case it wasn’t clear, it wasn’t just the angles of the tabs that were out of alignment, the tabs mustn’t be evenly spaced around the rings so you have to rotate the top ring till the tabs lines up with the bottom ring’s tabs and even then they’re not lined up spot on so the spreader plate is on a slight angle which is why I thought it could use a weld to stiffen it.
    #178860
    OK must be you or your one then :laugh: Maybe for piece of mind then Tony a tack here and there
    Come to think of it all of mine arent exactly 90 degrees :dry: Although its never moved or caused concern and its done some work its been dragged all over the place for 12months now and used by heaps of people.
    Still a good thing even with a tack if required ;)
    TISCO wrote:
    Just letting you guys know that we now have LA CORSA Tyre changers in stock.
    RRP $120
    OLD BULL PRICE $102
    Scott
    I see Sutto’s have more of these in stock when I was there this morning and also noted that Ballard’s are 140 bucks :ohmy:
    We are now sold out of these babys, we are trying to get some more but might be a couple weeks,
    But the price will be $120 which is still cheap.
