Home › Forums › Mud n Tar Suzuki Bikes Forum › Mud n Tar Suzuki Bikes Forum › Chops banana is dead
This topic contains 128 replies, has 0 voices, and was last updated by Greg 16 years, 9 months ago.
February 6, 2009 at 10:30 am #95829
So Chops banana stopped 6kms from Hillend after not missing a beat, it left him looking like
Even an old pro like boulder couldnt massage some life into it which surprised me some
So I took it to fatheads today and we proceeded to diagnose the non starting banana and even after removing the carby and a stripping, cleaning and a rejet whilst apart no joy. The plug was remaining dry? Fathead and I both looked at one another and said valves!
Yes it had closed up one inlet, and done a job on it to boot, the valve is sharp enough to shave with, we dont know why, its only one of the two inlets and it is rooted. The pictures dont do it justice but you can see how sharp the edge is if you look hard enough
You can see the top left valve is sitting further into the head
Sharp edges
Evan after the cones lol
Fatheads head man has broken ribs so how long it will be we are unsure
Why one has worn so much we dont know, there is no dust in the intake or the carby nothing, he looks after any banana that has done 50,000kms + and no dramas
February 6, 2009 at 10:33 am #121127I wondered about valves, given there was spark and no fuel. Bit of an odd thing to happen. Any other damage?
February 6, 2009 at 10:37 am #121140Fixed the pictures ECKS, no other damage, I did the valves when he got it 1100kms before this and the same inlet was tight and I re shimmed it, must have been on the way out and was already into the valve face and seat
February 6, 2009 at 10:39 am #121128Sad to hear mate:(
Was Chopper using the Valve addative in his fuel ???
February 6, 2009 at 10:41 am #121142Could have been worse then. I have heard of banana’s self destructing, although not usually from valves.
February 6, 2009 at 10:45 am #121129Got a few ideas why the valves wear out on one side same as the CRF250 (they do it in a short time)I will have to tell you my theory over a few drinks when I see you
February 6, 2009 at 10:48 am #121144Nah nah Bull, post em up here!
Are bikes left or right handed? Is that the problem? Left handed bikes don’t last?
February 6, 2009 at 10:48 am #121145I will look forward to it bull, I have an idea as well, well I know why would like o see if we have the same idea, bet we do :laugh:
February 6, 2009 at 10:57 am #121130Care to share said theory/theories?? it’s all interesting ( well i think so in any case??) I’m a tad curious to hear BOTH theories on it? have a mate or two riding these….could be worth the knowledge?
February 6, 2009 at 11:00 am #121152These dont do valves Husky, dont worry your friends about it, just make sure they do their air filter all the time.
February 6, 2009 at 11:12 am #121146The problem I believe is that the coolant exits from the r/h front of the cylinder head and there is a large exhaust port blocking the coolant path around the l/h side of the head and this causes a hot spot around l/h exhaust valve which causes core shift and moves the inlet boss off centre and causes the valve to scrape on the valve seat and wear itself out faster
this is just my theory
I have some very simple and cheap ways to test thisFebruary 6, 2009 at 11:14 am #121166Mine is more direction of air flow based when looking at the flow paths in the head
February 6, 2009 at 11:15 am #121167KTM Bull wrote:
Quote:The problem I believe is that the coolant exits from the r/h front of the cylinder head and there is a large exhaust port blocking the coolant path around the l/h side of the head and this causes a hot spot around l/h exhaust valve which causes core shift and moves the inlet boss off centre and causes the valve to scrape on the valve seat and wear itself out faster
I have some very simple and cheap ways to test thisNo how many people will I have to kill , Bull the words will blow their minds
February 6, 2009 at 9:46 pm #121170
AnonymousSorry to hear the flying bannana isn’t a quick fix. It looks like it could have been worse though.
TB is the valve stem okay?
February 6, 2009 at 9:49 pm #121239
AnonymousWhat about the the big red beast ?
Had any chance to look at it.. -
