Home › Forums › General Bike Talk › Cleaning air filters these days
This topic contains 27 replies, has 0 voices, and was last updated by Steve Wyeth 13 years, 5 months ago.
October 16, 2012 at 3:05 am #101955
What does everyone do for this most basic of maintenance tasks?
“In my day” it used to be just wash it in petrol, squeeze the crap out of it, let it dry (evaporate) a bit, then give it a good dose of any old oil, slap on some grease around the seal and that was it!
Now it seems “don’t use petrol it damages the foam and glue”, use a “special” (insert: expensive) filter cleaner and filter oil …. only bit that seems the same is the grease!
I agree with the specialised filter oil as the new ones are pretty good (tacky consistency etc) … but what does everyone do for the most basic bit, cleaning it?
razzle
October 16, 2012 at 3:11 am #230828i use Notoil razzle its easy to get consistant through the whole filter and its easy to clean with the notoil cleaning powder but i think every one has there own pet way of cleaning but thats the way i go
October 16, 2012 at 3:46 am #230829Lefty sells a gun filter kit Razz, PM him worth the money and I can bring it to Coffs if Lefty isnt going.
See filter kit on the link belowhttp://obtrailriders.com/index.php/forum?view=topic&catid=28&id=128404
That filter cleaner and Motul filter oil will see you covered from my experience with the bikes I look after
October 16, 2012 at 3:47 am #230836I use turps to clean mine then soapy water, dry it off and oil it up using Motul or similar filter oil.
October 16, 2012 at 4:54 am #230838Don’t use petrol as it deteriorates the foam. Turps seems to work well followed by a good wash in soapy water and then rinse it.
Use a quality filter oil because it is tacky compared to engine oil and won’t just drip into your air box leaving your filter dry.
Dont scrimp on filter cleaning as it may well stretch your modern 4 stroke life to at least 3 or 4 years before a big end bearing etc flies to pieces rather than a worn bore from a dirty filter…..October 16, 2012 at 5:56 am #230830I only use turps. If you can afford to it cuts drying time.
Just keep rinsing in fresh lots of turps till there is no residue in the container and no colour in the turps then dry. I like a 5L ice cream container as its easy to clean out – which you need to do after every rinse or the whole process is pointless!!
You can recycle the turps for the first few rinses by pouring off the stuff above the sediment from your wash container back into a old turps container and letting it settle then pouring the cleaner stuff off the top. Make sure you do the final couple of rinses in virgin turps (you know, turps made from freshly pressed virgins!!) to make sure no fine material stays in the filter.
Two filters makes the job easier as you always have one dry and ready to oil!
As for oil, I am of the old skool persuasion, I like filter fix which is mineral based (not water) so tends to stay put on the wet rides.
IvaOctober 16, 2012 at 6:13 am #230831Oh, the Nundle boys all wear gloves for the process which is probably a good idea, when i die of cancer you’ll know they were right!!
:blush:October 16, 2012 at 7:17 am #230832I was a Turps user for a long time,, then I got the Filterclean Kit from Lefty that TB mentioned.
It is good and easy to use,, only prob is evaporation, so the bucket needs to be sealed tight & kept away from heat and all good
October 16, 2012 at 8:35 am #230844Theres some product reviews or such on this topic raz, look around. TB started it I think. I have been using the cleaner and Motul oil they recommend. The cleaner is reusable.
October 16, 2012 at 8:55 am #230833October 16, 2012 at 8:56 am #230849Thanks everyone, some good advice as always.
I never thought of needing gloves! And am a little surprised that the Nundle boys use them
… having said that I think I’ll be getting some though.Iva; you’re not going to die of cancer, you’ll just have really dry old prune hands :laugh:
TB; I cant make Coffs unfortunately, damned OS work commitments! :angry:
Thanks again everyone.
razzle
October 16, 2012 at 11:05 am #230851razzle wrote:Thanks everyone, some good advice as always.I never thought of needing gloves! And am a little surprised that the Nundle boys use them
razzle
Razz if you purchase it from Lefty by chance I will drop it at my mates business at Kempsey for you to pick up if ya want. Offer is there is all
October 17, 2012 at 12:14 am #230852razzle wrote:Thanks everyone, some good advice as always.I never thought of needing gloves! And am a little surprised that the Nundle boys use them
razzle
Those cunning Nundle Boys, they were telling me it was OHS but all the time they was thinkin’ of how thier Goats would react to prune hands !!
Clever goat herders!!October 17, 2012 at 3:21 am #230867Turpentine for me with Motul air filter oil
I have been using that for recipe for many years
When we bought my son, Tims first bike (KX60) we washed his filter in petrol and it literally dissappeared in my hands.
:ohmy:
Like Iva, I also recycle the turps a few times, using the settling procedure and I also use a rag to filter most contaminants when pouring back into the bottle.
Another tip is to apply the new oil to the filter through a squeezy tomatoe sauce bottle. Someone told me that recently and it works a treat. I then place it in a plastic bag and fondle/caress it gently to get even coverage.
Will have to try one of the proper cleaners such as the one Lefty is selling to compare.
MurphOctober 17, 2012 at 3:59 am #230903I am using Motul oil but cleaning with kerosene then rinsing in soapy water.
