Coffs Harbour 25th to 27th November
Home Forums Ride Gatherings NSW Rides Coffs Harbour 25th to 27th November
This topic contains 359 replies, has 0 voices, and was last updated by  damien turnour 14 years, 4 months ago.
Viewing 15 posts - 301 through 315 (of 360 total)
  • #211881
    I have been talking with STM today and he’s asked that I post up the cornerman system. We know most riders will be familier with the system but if you have any doubts about how it works please read it as the success of the ride depends on this system.
    The Cornerman System
    Lead Rider: In charge of the ride, he/she determines where the cornerman are, the direction of ride, stopping points and what to do when there are problems. The lead rider will usually be wearing an Orange hi viz vest.
    On rides with larger groups we may use 2 lead riders. One will be the leader of the ride and may not have a vest but will be up near the front of the pack keeping check on the riders and the ride in general. The other one will be the lead rider with a vest and out front putting riders on corners.
    Sweep Rider: The Last rider in the group. He/she is in charge of sweeping the ride, waving you on, back-tracking missing riders, helping with broken bikes and injuries and also responsible for informing the Lead Rider of problems. The sweep rider will be wearing a yellow hi viz vest.
    On rides with larger groups we may use 2 sweep riders. This is to allow more help at the back of the pack and also if there is a break down one sweep can stay with the rider and help out and the other can keep the group moving.
    We may also have sweep riders within the ride group. These riders will have first aid kits, tools, cameras and some sort of riding ability and be willing to use them. They will wear punk coloured vests.
    Cornerman: The cornerman is just a rider who has been put on a corner by the Lead rider. The Lead Rider will tell/signal the cornerman which direction to point his bike in. The cornerman will then point the bike in that direction and stay there until the Sweep comes and waves him on.
    In a big group the lead rider may drop two or more cornermen off at every corner to reduce the spread of the group, and you have someone to talk to at each corner. If there is only one rider stop and become the additional cornerman
    How it works
    When approaching a corner, intersection or hazardous area, the LEAD rider will indicate to the next rider following to take position at the corner/intersection/hazard. If this rider happens to be you, the LEAD will usually point to the position on the corner where he requires you to position your bike. Indicate to the LEAD that you understand and then place your bike where indicated and make sure you are FACING the direction that the LEAD went. If this is an intersection, try to block off any exit that is NOT being used. Also make sure that you have positioned yourself in such a way that every following rider can clearly see you. If you are behind the lead rider and you pass a corner that the lead rider does not see or that you think people may get confused on, stop anyway.
    Once you are placed as a cornerman DO NOT LEAVE THE CORNER until the SWEEP permits you to move. In the event that a problem has occurred with a following rider, you must MAINTAIN YOUR CORNER for however long it takes. The LEAD will eventually return to find out what the problem is.
    All riders approaching the cornerman will see the direction of the bike and go that way. If someone misses a corner then the cornerman will inform the sweep when he arrives, the sweep will then go and find the missing person.
    When the SWEEP arrives he will indicate that you are to move on. You then take position IN FRONT OF THE SWEEP. As you pick up cornermen they will take position between yourself and the SWEEP and eventually you will get back to the front and become a cornerman again.
    Situations where a LEAD will drop a cornerman:
    •Where we are turning
    •At a confusing intersection
    •Where a hazard exists
    A LEAD rider may not necessarily drop a cornerman on a main trail if it is obvious that we are travelling straight.
    TIPS
    •To help keep the group moving be ready to ride off when the sweep rider gets there.
    •If the sweep rider is behind you and you are coming up to the next corner, tap your helmet so that cornerman knows he should be ready to take off.
    •Do not stop around blind corners. Give each rider an oppotunity to see you and which way to go.
    •Look before you cross a road, even if there is a cornerman there! It is your life, keep it!
    •Be careful when passing people. Enduro’s are for racing, not trail rides. If someone is behind you wanting to get passed, point a leg out to let them pass at a suitable point
    •If you get lost, go back to the last place you saw members of your group – SLOWLY – and wait. Don’t move again. someone will realise your lost and back track to find you.
    #211883
    If there is anyone in my Saturday morning group who would like to take on camera duties and be excluded from cornerman duties let me know and the job is yours.
    Nickj, Dupsyam4 and Rob400 came down from Yamba and Corey8 and Nate80 came up from the Bucca. The idea was to split into two groups of three riders and Nick and I lead our respective loops. I had set a meeting point at an intersection which I thought would be similar time for both loops. Me and Corey and Nathan pulled up there and as soon as we took our helmets off we could hear bikes. In less than 1 minutes Nick and his crew showed up. We were blown away by how close we had come to being there at the exact same time. Now I know when you have a big group all sorts of things can go wrong and hold the group up but it is comforting to know that I have the loops even when ridden in flow.
    We then rode as a group for the rest of the afternoon and Nickj and I swapped bikes all the way home. Once I got used to how to treat the DRZ I had a lot of fun and Nickj was ripping on my little Yami. I reckon a smaller trail bike may be on his list for Santa.
    I have done everything I can to prep the tracks and although a little dusty today they are in top shape and now it is in the hands of the weather Gods.
    Cheers to everyone for a top ride today and I can’t wait till 2pm Friday so we can get this party started.
    What great ride !!! I realized after about 20 minutes that I had my loop nailed as it all came together ;) DY4 , Rob 400 and myself said we would have a nice slow ride to really learn the loop…..
    Yeah right !!!
    Didn’t take long to forget that and the pace was on , I had a great time on STMs 250 ( thanks mate ) and I have to say these trails are in top condition and some of the best around :woohoo:
    See you all Friday !!!
    #206215
    Please make sure you have read the first post on page 1 of this thread. If you have any questions pm.
    Just to keep it all legit
    * This is not a paid ride, there is no money changing hands it just me going for a ride and you have decided to follow. I am not responsible for you, your bike or your belongings. If you are not happy at any stage with any part of the ride, you are free to leave and not participate, remember you are joining me of you own free will. If you have a friend that’s a fancy talking lawyer stay home with him and have fun together.
    * This is a trail ride, sort of an adventure tour as such, don’t see the word race there do you? No because its not a race. If you are a hero racer or a hero stay home with old mate and his lawyer buddy. (besides I am the fastest, I am the only one that knows the way )
    There are many hidden obstacles, rocky sections, blind crests and curves, it may be dusty, it may be muddy so please ride within your limits, if you feel you are slow (not that you will be) you will be faster then a guy laying on ground waiting for help, don’t spoil it for yourself and everybody else.
    * If you ride in such a way as to endanger yourself or anyone else on the ride you will be told to leave, this includes passing people and such trail ethics, my decision is final if you dont like this or anything else here DONT COME
    Old Bulls must also state that this is NOT an organised event and that no organisational function is undertaken or initiated by Old Bulls with respect to such rides. There are no set tracks/ routes and members ride at their own time and discretion. Old Bulls forum is a medium used for organizing rides by members and in attendance Old Bulls takes no responsibility or liability for injury or damage to persons or personal property that may occur
    Here’s a teaser from our Pre-run last weekend. It’s my first real go on a 250 and I had a ball
    #211885
    Hey King dust won’t be a problem if I read that right there is a 90% chance off 145 mm of rain in 4 or 5 days
    They called for a bit this week and we got none. It was a bit dusty last weekend so if they are right it will fix that!
    If anyone coming to the Coffs ride this weekend has an old exhaust pipe in their shed that they don’t want please bring it along as one of the Old Bulls is converting gas bottles and pipes into pot belly heaters/ BBQs.
    DY4 (or Spud ) is an awesome metal artist and when I saw this pot belly I bought it then and their , he kept it for a day to customize it and here it is.
    The pipe at work !!!!
    I will start a new thread on how you can order one of these too at Coffs , but any pipes will be very appreciated.
    Spud didn’t ask me to do this but as his computer is down I thought other old bulls may like one ;)
    #212150
    It’s Official. It will not be dusty!!!
    :D :D
    This is going to be fun , goggles with foam pulled out are now packed !!!! :woohoo:
    #212171
    The dust suppressant at work !!
    #212172
    Who else is now getting super excited?
    #212148
    http://www.youtube.com/watch?v=f9mYIIlLV38&feature=youtube_gdata_player
    That trail looks sweeeeet! Is it Friday yet??
    Sitting around at home for the last 2 days waiting to go has been hard
