Coolant advice
Home Forums Tech Help Tech Help Coolant advice
This topic contains 3 replies, has 0 voices, and was last updated by  Dwayne O 14 years, 5 months ago.
  • #100528
    Since I had my little mishap on the Sunday ride I have repaired the radiator (looks to be successful)
    But am thinkng of waiting till I am 100 percent sure it is before I replace the coolant.
    So the question is,
    I used about half a 500mls of water from the cmelback over the 3 times that I topped it up on the home run. IS there any issue with leaving it as is for a few weeks before changing the coolant and giving the system a flush ???
    I did add some glycol concentrate when I got home to top the level to full.
    :whistle: :whistle: :whistle:
    #209464
    Cant see a problem for a couple weeks, but sooner you get it back to the correct levels the better
    Yeah No drama’s with that Eag’s. ;)
    Cheers Lefty
    #209473
    That`s what I thought would be the case,,, Thanx mate I will flush it and change asap ;)
    Cheers to you too Left One :)
