coolant in oil after drowning bike
Home Forums Kawasaki Bikes Kawasaki Bikes coolant in oil after drowning bike
This topic contains 6 replies, has 0 voices, and was last updated by  Nick Dole 13 years, 1 month ago.
  • #102233
    Mick O’Dea
    Hey guys just wonderin if i can get some help or advice. i have a 08 klx 450, after i dropped it in a river, i got all the water out an then tried to get it goin. i ended up towin it behind a ute, it ran, but really rough.. i dropped all the oil an now when it starts, the coolant leaks into the oil.. cracked head? head gasket? or seals??
    #234897
    Looks like nobody wants to help. I’ll have a stab. Going from what you say – either head or base (depends on the bike water galleries) otherwise water pump seal. Seeing as the bike went from super hot to cold real quick the worst case scenario is warped head. But really, sounds like you still have some moisture in the oil rather than coolant. Unless you tell us that after a ride you have to add 1L of coolant every time….
    Your unlikely to get the moisture out of the gbox/motor in one oil change.
    #234898
    Mick O’Dea
    Thanks for the help mate. But the bike was cold when it hit the water. I hav replaced the 2 water pump seals. I’ve drained the oil about 5 times now. When I kick it over it starts good but coolant starts to leak out the weap hole an then the oil gets coolant in it.. Hope it ain’t major but ill hav to take it in to a Moto shop. Thanks for ya help mate
    #235135
    Missed this sorry, sounds like a water pump to me :S Maybe Nick from Tekniks will chime in with his thoughts.
    Pump housing? Electrolysis in the housing or the case where it transfers?
    Could be head gasket also.
    #235144
    Good point if it hydraulic locked, cylinder pressures go up and pop. Normally there is a mechanical failure like a rod bending etc
    Worth a look
    Nick Dole
    Ok, i’m confused. The engine was cold when it went in the river. We you rolling with a dead engine?
    First issues first. Have you flushed the engine out to the point you have no water at all? Water will stay in the engine for many oil changes and corrode the bearings. I use a half engine oil half ATF mix as a flushing oil. the ATF has a very high detergent content and will hold the water in suspension more than engine oil so you can drain it out. Don’t leave it in there for a ride, just 15 minutes, a quick lap around the block and dump it again. Keep washing out the oil filter, no sense in using a new filter every time.
    The water pump has a leaking inner seal. You are replacing the outer seal only i’m guessing. The weep hole issue is the cavity between the inner and outer seals. the hole is there to show if you have a leaking waterpump seal. The outer seal is to stop water escaping from the cooling system. the inner seal keeps the engine oil and coolant from mixing. The weep hole sits in the dry cavity between them.
    Seeing as it sounds like BOTH seals are leaking i’d have a good look at the shaft and bearings, a partly collapsed bearing could be causing the seals to leak. In theory best practice is always replace the shaft but we cheat a bit on that one when we can. HOPEFULLY the bearings are not worn from moisture in the oil as i’d be sweating about main bearings next.
    Lastly, how does the engine sound? Noisy in a grumbling bearing kind of way? Did you hydraulic lock it? was it running hard when it hit the water or just idling? When you towed it was the rear wheel ever locked and you seat bounced it past?
    If you have hydraulic locked the engine then forced it over top dead center it needs a new connecting rod. I weeny bit of a bent rod will break at 8000 rpm and become a metal cutting saw the consumes your barrel/head/cases/.gearbox. I’ve seen it first hand. Not nice.
