Coolant out the weep hole klx450
Home Forums Tech Help Tech Help Coolant out the weep hole klx450
This topic contains 17 replies, has 0 voices, and was last updated by  corey heather 16 years, 5 months ago.
  • #97260
    Can any one tell me is it normal and i’m guessing NO that my klx450 weeps out the weep hole under my water pump only when it’s getting a thrashing.
    I have just put a new waterpump seal in and replaced fluid with engine ice.
    #154801
    No mate if its coming out the weep hole, the weep hole is there to tell you the water pump seal is leaking. If it wasn’t for the weep hole the coolant would get passed the water pump drive oil seal and get into the engine oil.
    Sorry sounds as the the water pump seal job wasn’t done correctly or there is another problem in the water pump area but normally its the seal
    Bill
    What was the shaft like if it has a few ks on it there could be a grove cut in to it from the seals and the new ones wont get to seal on it tightly so under load/pressure it will weep some coolant out
    check your coolant for foaming by shakeing some in a clear bottle
    #154806
    what will it mean if it is faoming?
    #154810
    Bill
    Its no good for a cooling system
    #154811
    Nothing as far as leaking from the seal goes, thats just a whole other thing :P Just fix the leak before you worry about that :laugh:
    Bulls right as far as the wear in the water pump shaft goes or in maybe not fitted square in the housing etc.
    Bill
    Foaming coolant will cause severe cavation in and around the impella and cause a stall in the flow of coolant and this makes the impella hammer around and load the seal bearings of the water pump :S
    #154817
    Yeah it could, But really Bull shouldnt we cover the simple things first, someone just had the water pump apart, I mean have you heard of many late model KLX 450’s with the above problem I dont think he should worry about that yet, I mean there are so many different things to get out of the way before he gets to the above isnt there including the pump thats leaking that someone had apart
    stop thrashing it….bikes are like women.. they respond to some TLC…just my opinion :laugh: :laugh:
    #154820
    Bill
    Sure but he also changed coolant so maybe try just water and its cheeper to use till the problem is found but like i said in my pm to Corey8 i am happy to look at it for him if he is close to Port and check seals and shafts ect
    #154830
    Yeah try that
    Fez
    Fair dinkum Bull + TB only on a totally anonamus web site can you get 2 very knowledgable blokes to look at ya bike for nothing but parts cost, I say this TB because I know if you were close you would have offered too. I LOVE THIS SITE.!!!!!!!!!
    #154834
    Ok new seal ready to go back in BUT before i do it i was told to put rudder grease on it to help it seal.
    Any one else heard this before?
    #155845
    Can Any one tell me if a seal is suppose to have to flat side or sping side out? i feel it may have been installed wrong
    #155947
    Hey Corey,the spring side of the seal should be on the water side of the pump.
