Home › Forums › General Bike Talk › Cornerman System
This topic contains 6 replies, has 0 voices, and was last updated by Greg 17 years, 6 months ago.
August 31, 2008 at 11:22 am #95073
AnonymousI did a search for info about the “cornerman system” on the site but nothing showed up.
Would it be worthwhile putting it as a sticky somewhere so that everyone is aware of how it works and any peculiarities that may be different from other systems they may have used elsewhere?
N
August 31, 2008 at 11:24 am #107704Good idea Nigel. I am sure someone can do it.
August 31, 2008 at 11:25 am #107708I have started a thread, later in the week will finish it and post it.
August 31, 2008 at 11:27 am #107705Compliments of KEG from another site….
CORNERMAN BASICS
You have a lead rider (in front all day) and a sweep rider (at the back all day)! They usually both wear bright vests so you know who they are. You ride between them all day!If you are behind the lead rider coming up to a corner, he will point at the corner. This means you stop your bike, face it in the direction he went. Once everyone has passed the sweep rider will wave you on, to go in front of him.
Often down main roads with tracks running off them the lead rider may not drop cornermen there, as it is obvious that they are not turning!
RIDERS RESPONSIBILITIES
– NEVER LEAVE YOUR CORNER. Somethimes you can be there 1 hour if someone has broken down. Stay at your corner . The system depends on everyone!
– Nod at the lead rider so he knows you recognise you have to stop when he is pointing.
– If you are behind the lead rider and you pass a corner that the lead rider does not see, that you think people may get confused on, stop anyway.Be careful when passing people. Enduro’s are for racing, not trail rides.
If someone is behind you wanting to get passed, point a leg out to let them pass at a suitable point – unless they are NSW blokes and you think you can roost them.
OTHER TIPS
– To help keep the group moving count the riders going through, and be ready to ride off when the sweep rider gets there.
– If the sweep rider is behind you and you are coming up to the next corner, tap your helmet so that cornerman knows he should be ready to take off.
– Slower riders (especially in Winter) should take off at the front of the group after eeyone has stopped. The ground will be less cut up and it will be easier to get up the hills, before all the good riders carve it up.
– Do not stop around blind corners. Give each rider an oppotunity to see you and which way to go.
– The lead rider may stop you before a hazard, such a s a log or bog hole, not just a corner!
– Look before you cross a road, even if there is a cornerman there! It is your life, keep it!ON COMING VEHICLES
Try to remember how many riders are behind you and if you pass someone. Put your fingers up to indicate how many are left. The lead rider may drop a cornerman there if the track does not leave opportunity for passing.BIG GROUPS
When you have say 16 or more riders it is recommended that you drop two cornermen of at every corner. This means the group can only get 8 corners away in this example. Also you have someone to talk to at each corner.If you are coming up to a corner and there is one rider on there. Stop. He should have his hand up so you know!
September 1, 2008 at 7:36 am #107709micknmeld wrote:
Quote:Compliments of KEG from another site….!:laugh:
September 1, 2008 at 8:33 am #107706Yep I did steal it from another site. Credit to KEG, whoever he is, for taking the time to post an article on the net. That’s how it works.
September 1, 2008 at 8:35 am #107731Careful Mick black magic !
