Cracked Swing Arm
Home Forums Yamaha Bikes Yamaha Bikes Cracked Swing Arm
This topic contains 17 replies, has 0 voices, and was last updated by  Jeffrey Smith 15 years, 11 months ago.
  • #98279
    Is it a known fault that WR450 swing arms crack?
    I noticed that mine has a hair line crack on the RHS top where the chain slider is.
    I will take it off and get it welded, but was wondering if antone else has heard of this happening to WR’s or have I just broken my toy?
    #175343
    Roy
    Can’t say that I have heard of any. Not saying there hasn’t been any though.
    #175347
    Bloody Yamahas better get yourself a KTM.
    its a common yamaha thing Dan,
    it cracks in the exact spot where the bikes previous owner used to whack it with a stick once he had finally realised yamahas were shite :laugh: :laugh: :laugh:
    see the light Daniel, the big orange light…..
    folllllowwww it :laugh: :laugh: :laugh: :laugh:
    #175353
    Thanks for the advice Menace and Chris. NOT
    I will stick with blue and just get it welded :)
    #175356
    Dan are you 100% sure its cracked not a fabrication casting and if so where on the swing arm is the crack?
    just stick a blue flame sticker over it :laugh: :laugh: :laugh:
    she’ll be right ;) :P
    #175374
    Trent
    I reckon that’s what caused it to begin with, the bike got pissed off and said “I want a new owner this bike molester ain’t riding me again!” :D
    #175349
    Hahaha, listen to him!!
    Wouldn’t have happened on a 2 stroke though :P
    I can’t say I’ve ever heard anyone complain about a broken swingarm on here, on any bike for that matter.
    At least it’s in a position where it can be easily welded.
    #175408
    This is not a common fault on any modern bike Dan, like TB said casting mark or fault maybe?
    #175419
    must be riding it to hard dan :laugh: B)
    #175422
    Never heard of that one Dan. Closest I have come is seeing a Gas Gas lose all the rear sprocket bolts and chew a 1-inch tear right through the swingarm as it rotated and quickly destroyed itself!
    As TB said, are you positive it is actually a crack? Seems like a weird place to let go – not the most stressed point of the part.
    #175424
    I pulled the swing arm out this arvo and it definately has cracked. Not a big open gaping crack, just a small hair line, not even wide enough to get a stanley knife blade in. I think some of the problem has been the chain slider has been rubbing on the swing arm which has eroded a bit of the swing arm and the crack has appeared.
    Tony came around this arvo and took the swing arm with him to weld it up. I dont think that the crack would of ever been a problem and it could of been there for ages???? for all I know.
    I think with a bit of weld on it, it will be right, I hope :huh:
    I did find that I had a seized bearing in the bottom link bearing which I have since re-greased and put back together.
    #175438
    I wouldn’t worry if it’s a longitudinal crack Dan, sounds like an internal casting flaw has surfaced with a little wear.
    a good vee groove with a grinder and a competent TIG operator and like new again.
    #175344
    Are you gonna weld it cold? it might be ok, but I’d be doing a bit of investigating first…. you don’t want to make it brittle.
