Crf 250x
This topic contains 23 replies, has 0 voices, and was last updated by  Adrian Snowden 11 years, 6 months ago.
Viewing 15 posts - 1 through 15 (of 24 total)
  • #104156
    Nick, my little 250 is suffering from an overweight rider trying to belt thru single trails. I don’t want to spend a fortune as the minister for war and finance is a bit touchy about the cost of my toy, so what basic mods could be made to the standard bike that would accommodate a 107kg rider plus gear without having to sell a child?
    Cheers snowy
    Ps cumon boys let the shut laying commence, the sites a bit politically correct atm
    #259354
    just sell the hand-grenade and get a 450 easy fix :blink:
    #259358
    Put a 500 2 stroke in it :laugh:
    Ring a Ding Ding :woohoo:
    You could try lower gearing to give a bit more snap mate. Also make sure you are not running a big tyre on the rear as that will suck some power.
    If 107kg is without gear then maybe skip a few parmies. That should liven her up.
    I’m with STM mate. Wack a big arse sprocket on the back. It’s not like you want to be cruising at higway speeds on it.
    #259363
    Lose weight fat arse.
    #259362
    I found the stage 2 cam gave a mid range boost and as I don’t ride that much open stuff the lower gearing as STM said is the go !!
    I had wiseco race piston and gaskets etc but that’s costly !!
    I second this highly wise comment.
    #259365
    Pull all the unwanted weight out of it and give it a run daily then work with the poor bike.
    #259366
    Cris
    Talk to Deuy he has a 310 husky in the shed and your 250 might just suit his daughter better.
    #259364
    Nick Dole
    Hi Snowy,
    We talking engine or suspension here?
    Suspension is where is start, just put a spring on the back of it. $155. Do the forks if you have another $155. Rear spring is an easy DIY. Forks are. Little harder, I’m sure you can find an OB who can help you.
    Engine. The 250x is a great engine. The people who write them off have never owned one. I’m 115kg plus gear, Hobsy from ADB/Transmoto was 125kg when he owned one from 04-09. He still talks about it today as the best bike he’s ever owned. I had an 05 and still miss it. Better in the bush than my 10 YZ450.
    I think they go ok stock. When the inlet valves start pulling through I put Kibblewhite valves in them, inlets only. You have to get the seats cut too. I can do it all, not expensive.
    Run the stock header and muffler. They work very well despite looking and sounding ugly. Run an R muffler if you must change it. If you really have to have more power, stage 1 hotcam. More power everywhere.
    Keep on top of the air filter.
    I’ll add this last line as a catch all. The above is my opinion. If you disagree with me, that’s ok, I don’t give a shit. I’m simply expressing my opinion and will not be entering into an argument.
    #259367
    Geese!!!!!
    I meant suspension wise. I don’t want too go fast it’s too scary,
    #259368
    Thanks Nick, I’m interested in the suspension as its quick enough now and I’m not ringing it’s neck. Do you suggest rear spring first or fronts first? I promise not too argue as I obviously know nothing gab out suspension.
    Teknik wrote:
    Hi Snowy,
    #259359
    Alan Heather
    Yep I agree best move I ever did klx 450 :woohoo:
    #259369
    Steve
    snowy. buy your misses a new toy.to alleviate monetary complications .
    If you carnt perform.
    Or, more sex ,better physique,
    I know, hard to better perfection.
