CRF down!
Home Forums Tech Help Tech Help CRF down!
This topic contains 43 replies, has 0 voices, and was last updated by  murph the surf 11 years, 6 months ago.
Viewing 15 posts - 16 through 30 (of 46 total)
  • #258570
    singletrackmind wrote:
    My mechanic was just in and showed me some shots of the engine strip down. It turns out that there was 500 ml in the crank case and 700 in the tranny. 700 should be in both so some has gotten out or burned off but not enough to completely seize the engine. The strange part is that the bottom end is smick. The barrel looks like new and the piston, crank and bearing are perfect. The head however is a completely different story. It looks like something dragged out of Hiroshima! One valve has been welded closed and the whole thing is just a charred mess.
    He is at a loss to explain how the head could be so burnt out when there is no damage at all the the rest of the engine. At least that will save me a bit of coin though. I will update as I know more.
    Think about it Scott you were around nick the morning after chicken patties for tea. Perhaps you caught an air of full of straight methane to which your bike added the spark – instant Hiroshima.
    #258506
    Mike Wyeth
    That’s real wierd , but maybe not as bad as first thought mate :unsure:
    #258606
    Cris
    Mmm don’t them Hondas have a valve problem?? Wounder if it was a valve spring that let go??
    #258608
    I did the full valve job at 15 hours and switched to kibblewhite with new springs.
    Not good mate, but a whole lot better than I might have been.
    C u on the trails again real soon :woohoo: :woohoo:
    #258508
    Nick Dole
    No oil supply to the top end, 700cc is heaps! Ha, well, heaps for a 250 anyway.
    How does oil get to the top end again? up a stud cavity or is there a gallery?!
    Anyway, time for kibblewhite inlet valves, hot cam stage 1 and an 09 R head.
    That’s crap luck, very unusual though.
    #258616
    Hey Nick,
    It uses a gallery and it is clean and clear. We suspected this may have become blocked but that was not it. Could the timing have skipped somehow therefore only affecting the top end?
    It had Kibbles in there already but I will be needing new ones. They damn near melted and the head is a charred mess. Thanks for the advice. I will start putting together a shopping list.
    Nick Dole
    When you get it back together run it with the rocker cover off to make sure you have oil pressure at the cam. I don’t recall the 250 having an oil pressure check bolt at the head.
    Keep an eye out on evil bay for an 05-09 CRF250 R head and cam or see what Rock can do you a head for.
    #258668
    Alan Heather
    Hey Scott try crf,s only they have complete r heads new with kibble white valves iv brought parts from them there good to deal with.
    #258672
    The strip down is done and my shopping list is sorted.
    09 Crf R head
    08 Crf R cam
    Kibblewhite valves all around
    Kibblewhite valve springs
    JE high comp piston
    Stock rocker
    Stock shim buckets
    While it is in pieces I will doput new bearings in the linkage and swing arm and get my forks and shock serviced.
    There is a fair bit of work ahead but the process has begun.
    Hey STM,
    If you haven’t already done so, check the oil pump and see that it’s pumping.
    #258774
    adam wrote:
    Hey STM,
    Cheers mate. I forgot to include that but I am buying a new one also. It is pumping but I want to eliminate any possible cause.
    09 Crf R head
    08 Crf R cam
    JE high comp piston
    Stock rocker
    Stock shim buckets
    Scott, why the 09 head but an 08 cam?
    #258781
    09 Crf R head
    08 Crf R cam
    JE high comp piston
    Stock rocker
    Stock shim buckets
    Hey Snowflake,
    The 09R head is considered to be the best ported and the 08R cam gives the best all round power. Hot cams work down low or up high but the 08R is meant to give improvements at both ends.
    CRF250R’09 – OEM Head w/ Kibblewhite Valves & Springs[CO25RKWH9]$846.67 $758.99 Click to enlargeEach CRF’s Only head is professionally assembled with Kibblewhite stainless steel valves.  Valves seats are cut and a proprietary port to valve seat profiling performed for increased performance using a state-of-the-art NEWEN CNC machine.  This same NEWEN technology is used by top race teams in all of motorsports such as F-1, NASCAR, NHRA etc.  Don’t settle for less when teh best is so affordable.New OEM 2009 CRF250R headKibblewhite Stainless Steel Intake valvesKibblewhite Stainless Steel Exhaust valvesKibblewhite seals and spring kitNew OEM valve cottersValves professionally installedReady to bolt on and rideOPTIONAL: Header Studs and Head Gasket.  Performance porting service for even more performance from this head.NOTE: This head fits all years of the CRF250R and CRF250X.  It’s a very popular head for both CRF250R and  CRF250X models.  With Kibblewhite valves and valve springs this is a performance head with excellent durability. CRF250X owners expect to see up to 4 HP improvement with increased throttle response.
    Mike Wyeth
    09 Crf R head
    08 Crf R cam
    JE high comp piston
    Stock rocker
    Stock shim buckets
    Hey Snowflake,
    Impressive list of performance parts there Scotty ;)
    Does that mean I can include some big hills in this years noosa ride :silly:
